LinkBack (1) | Thread Tools |
#1
1990 LX hatch
Head gasket.
I have a bad head gasket, i bleu it. Time for studs, and a new set. Any opinions on a good boostable set for aluminum heads?
1988 Notchback
11.19 @ 122mph N/A
Cometic
1993 5.ohhhh
12.97 @140mph
tell me you didn't pop it being on 5psi or what ever? Had to be an old gasket. Either way let me know. I have the an oem fresh head gasket on ten psi with head studs. It's taken the beaten so far. I just stepped down two pulley sizes. So We will see what she makes on 13psi.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#4 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
You should weld the heads to the block
if only it were easier to weld aluminum to cast iron
look in the threads i have started, ryan made a recommendation in one of them for my setup (s trim)
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#7 | |
MLS gaskets like Cometic are pretty much the best you can buy but you need a 15 RA or better finish on your deck surfaces so the gaskets work properly. The gasket needs to be able to move as the head/block expands and contracts. The MLS gaskets are ridged compared to a conventional head gasket and will not "settle in". If the finish is to rough the gasket will just sit on the high spots of the surface and will leak. This is the reason you here people say their MLS head gaskets leak coolant, its because they didn’t follow the directions and have the deck surfaces machined properly. Cometic gaskets are viton coated and as long as the viton is still intact you can reuse the gasket which is typically 2 to 3 times.
#8 | |
1990 LX hatch
I really didnt want to take the bottom end appart to the machine shop. I was pretty sure the blocks surface was not in the RA. area for copper gaskets, didnt know about the MLS ones(thanks for the tip). I was looking at the graphite FRP gaskets with the pre flattened ss ring. whats ya think? Also do I use the heads recomended torque specs, or is there somthing I dont know about when switching to studs?
1988 Notchback
11.19 @ 122mph N/A
You will need to torque the studs as per stud manufacturer. Remember to use a thread sealant on any studs that go into the water passage area of the block. Studs are to be screwed into the block hand tight, do not over tighten them into the block. I can't remember the part number, but I used a Fel Pro head gasket that was pre-flattened and haven't had a problem as of yet.*Knock on wood*, but I'm only hitting it with a 125shot, and I have only done that twice. Never at the track yet, but soon I will.
1989 GT
KB 2.1L Flowzilla
I've seen mentioned that felpro 9333pt1 is good head gasket for boost.
#11 | |
Yes, that is another good gasket if you can find them.
1990 LX hatch
the carnage, not too bad.
1990 LX hatch
that was the 1011-2^ i think it might of been the 4th use of my torque to yields, that gave me the problem tho.
#15 | |
I wonder what the problem was....You sure do get your use out of your parts.
1990 LX hatch
Idk what I was thinking, they held up the first 3 times tho.
well, now i don't feel bad about using a gasket twice
#19 | |
1990 LX hatch
THere is 4 lbft diffrence between the two. Split the diffrence? Also will the special 1/2 inch to 7/16" trickflow washers, replace the arp head stud washers, or should I put the Arp washers on top of the trickflow ones?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/122833-head-gasket.html
| Are Felpro 9333pt1 Pre-flattened | This thread | Refback | November 5th, 2010 03:13 PM | |
Threads Similar to: Head gasket.
| Head gasket gone!! | ssprofession | 96-98 | 7 | February 2nd, 2009 02:03 AM |
| intake manifold gasket or head gasket? | rasalibre | 5.0 Mustangs | 5 | November 26th, 2008 05:37 PM |
| Head gasket | izze01 | 5.0 Mustangs | 8 | November 15th, 2008 07:23 PM |
| Head gasket? | Elder | 4V / SVT | 14 | June 22nd, 2008 12:33 AM |
| head gasket | popmyclutch | V6 Mustangs | 14 | September 12th, 2007 10:48 PM |
