87 Mustang GT T-top
Dropping the Tranny and need some help
Ok guys so im Dropping the Tranny for the 1st time. Note ive never dropped a tranny before minus my friends 67 Mustang. But I have a Tremec 3550 ( dunno if it makes a diff. or not ) And i dunno if there are any sertian things i should really avoid or if i have to do something to the driveshaft ( besides take of the U Joint ) or any tricks or anything like that. So im asking for some advice and help.
I have the car on jack stands now. So i just need to get under it and get going but since ive never Dropped a Tremec i dunno if there are certian things i should and shouldnt do. Like should i take of the shifter 1st? Or are there certian things that will hurt it or anything like that. Sorry if these are dumb questions but im just a guy trying to learn but i dont want to have to learn but destroying something and having to buy a new parts so i figured id ask now. Thanks for any help and tips guys, i really appreciate it! - Joe. |
take out everything in the way first. then take the driveshaft off the rear and pull it out of the tranny then unbolt the tranny and be careful pull it down. that easy!
SVTfocus, F250
take off the shifter handle, drop the midpipe, unbolt the drive shaft, disconnect the speedo and clutch cable, but a jack under the trans, take off the crossmember, unbolt and drop the trans
thank god t5/t45/tremec boxes are really light! it's cake brother
weeee foooord!
Lol! Tremecs are alot heavier than T5s.
1990 LX hatch
I allways dont jack the car up too much, and when I pull the trans I just ease it out, and lower it onto my chest, then gently roll it off me.
85 GT/86 SVO/2010 GT500
and then change your shirt b/c it will be coverd in tranny fluid (lol)
1988 GT
Try and have a budy with you to go on/off with the e-brake for the driveshaft back at the diff. Makes it easier with a second set of hands, also have a drain pan for the tranny fluid. I would use the jack once the trans is ready to come out, and obviously it has to slide back about 3-4" before it will drop down. GL and be carefull.
ALMOST FORGOT!!! make sure the back of the car is also on jackstands, atleast to get the drive shaft out. 10x's easier to get to the driveshaft bolts when you can spin it to get to all the bolts.
![]() Last edited by 88-gt-t-top; May 11th, 2009 at 10:44 AM. |
Not a hard deal really.. just do like everyone else said :
put ebrake on or wheel chalks at tires unbolt shifter handle unbolt x or h pipe put a jack under the trans unbolt the crossmember unhook the shifter cable at bell housing unbolt speedo cable from side of trans unbolt driveshaft bolts at rear end slide driveshaft out of trans catch trans fluid from where you just pulled the shaft out of lol unbolt trans from bell pull trans back out of bell while having a jack under it lower jack and pull the jack with trasn on it out from under the car |
1989 mustang gt
8th 5.70
O so true and wash your eyes out to get the 20 poundes of dirt out of them O and get some bandaides on those knuckles!
very true, but still much lighter than all these 4wd transfer case jobs i've been doing
weeee foooord!
Threads Similar to: Dropping the Tranny and need some help
| Dropping in a V8 | nickp008 | V6 Mustangs | 24 | June 9th, 2007 12:28 AM |
| Still dropping | MSTGGT00 | 99-04 | 14 | May 4th, 2007 02:55 AM |
| Dropping a v8 into my '01. | Dansby | V6 Mustangs | 18 | March 23rd, 2007 03:38 PM |
| Dropping A 5.4 In | built54 | V6 Mustangs | 17 | October 8th, 2006 02:16 AM |
| Dropping A 460 | tdurbin | 5.0 Mustangs | 6 | September 20th, 2006 09:52 PM |
