need help please, fuel problem!!!
Old May 11th, 2009, 10:53 AM   #1
joedaddy4's Avatar
1994 Mustang GT
joedaddy4 is on a distinguished road
ok i just installed a 255 lph fuel pump but the car still has the stock injectors and maf and now when i get to about 3000 rpm it cuts out and starts to sputter like its not getting enough fuel any advice or info to y this is would be greatly appreciated thanx
1994 GT 5.0, 302 c.i. studded and girdle, Cobra upper and lower, gt40p heads, 3.73 gears and stock T-5, boostbrothers turbo kit, master-power t70 turbo, pro-m mass air, 80# injectors, manual rack, tubular k-member, a-arms, upper & lower control arms
Old May 11th, 2009, 11:27 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'm assuming it didn't do this before you installed the fuel pump??? Was the pump new or used?
Old May 11th, 2009, 12:36 PM   #3
joedaddy4's Avatar
1994 Mustang GT
brand new walbro 255 lph
Old May 11th, 2009, 01:40 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You need to put a gauge on it and see what the fuel pressure is doing.
Old May 11th, 2009, 02:00 PM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
and a volume test if possible.
Old May 11th, 2009, 02:17 PM   #6
joedaddy4's Avatar
1994 Mustang GT
Thanx for the suggestions but do u know where I could get that done
Old May 11th, 2009, 02:59 PM   #7
1998 Cobra
13.24@105.66
I bet its maxing out your fuel pressure regualtor.
5 bucks says your fuel pressure is at 60-70psi.
weeee foooord!
Old May 12th, 2009, 12:41 AM   #8
1986 mustang gt
1fst5.0 is on a distinguished road
did u check ur plugs?
Threads Similar to: need help please, fuel problem!!!
need help please!! fuel problem joedaddy4 94-95 9 October 10th, 2009 12:43 PM
98 GT Fuel Problem stevo629 Modular Mustangs 4 October 9th, 2009 01:31 PM
Fuel Problem JerseyTrueBlue 99-04 9 March 23rd, 2009 11:28 AM
Fuel Problem tehdwarvenn 5.0 Mustangs 5 December 15th, 2007 11:18 PM
fuel problem????? haywood11 5.0 Mustangs 5 August 17th, 2007 11:30 PM
