vacuum line?
Old May 11th, 2009, 03:58 PM   #1
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Exclamation
vacuum line?
i was wondering if this could cause the tranny to slip or maybe slip im not sure
if my tranny is even slipping the rpms are just shooting around
Old May 11th, 2009, 05:25 PM   #2
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
AODs don't use vacuum modulation, that's why the TV cable adjustment is so important. Start there.
Never fast enough.
Old May 11th, 2009, 05:30 PM   #3
1989Gt.'s Avatar
1989 Mustang GT
where is that located?
Old May 11th, 2009, 05:33 PM   #4
95StangMX's Avatar
95 Mustang GT
up by your TB there should be two cables one for the TB and the other is the trans
Old May 11th, 2009, 05:46 PM   #5
1989Gt.'s Avatar
1989 Mustang GT
tb? lol
Old May 11th, 2009, 06:42 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
FORD AOD Automatic Overdrive
LIFT TAB TYPE-TV CABLE ADJUSTMENT
1. Lift tab up to unlock adjustment assembly.
2. Have someone push the accelerator pedal to the floor. While the pedal is floored, push on the throttle body arm to make sure it's bottomed out and actually wide open throttle. (Adjust throttle cable, if necessary).
3. While the pedal is to the floor, lock the tab on TV adjuster.
4. Mark this spot tight to the adjustment assembly with a knife or other thin marking device. This is the MAX TV mark.
5. Unlock the tab and slide housing towards bare cable 5/16" and lock tab. You can use a 5/16" bolt as a gauge. Make another mark up tight against adjustment assembly. This is the MIN TV mark.
6. Make another mark midway between MAX and MIN. This is MID-mark.
7. Adjust to MID-mark and road test.
BLOCK TYPE-TV CABLE ADJUSTMENT
1. Pull/push TV cable and block assembly out of throttle arm rubber grommet.
3. Push the locking tab up through the adjustment block, with a pocket screwdriver, so that the locking tab is standing up next to clevis pin as shown in the picture.
4. While someone is holding' the accelerator pedal to the floor:
Pull the cable rail HARD towards the end of the cable with one hand, at the same time engage the clevis firmly into the throttle arm grommet.
Engaging the clevis automatically locks the tab by pushing it into the block.
5. Pull the block adjustment assembly out of the grommet:
Make a mark, on the rail, with a hacksaw blade or knife up against adjustment block.
6. Make another mark 5/16" from the max mark out on the rail. (Use a 5/16 pan bolt for a gauge.) This is MIN TV mark.
7. Make another mark midway between MAX mark and MIN mark. This mark is
average or MID-mark.
8. Unlock the adjustment tab. Set on MID-mark and lock tab. (Push it down into block.)
Install into throttle arm grommet and road test.
ROAD TEST
In manual "3" it must have 3-2 kickdown at 50 mph (passenger cars).
CARB AND THROTTLE BODY INJECTOR MODELS: Seem to work best with setting
between MIN and MID.
PORT INJECTION MODELS (Standard): Start with a setting just under MID.
HIGH OUTPUT Port injection models: Start with setting just a hair over MID
Adding TV to attempt to correct pinging, chugging or lugging won't work. It Just causes thumps, bumps and extra wear. Set the TV so that the shifts are smooth and not late.
Old May 12th, 2009, 06:22 PM   #7
95StangMX's Avatar
95 Mustang GT
Darrell - great info.... I vote STICKY
Threads Similar to: vacuum line?
vacuum line ViperblueGT 5.0 Mustangs 24 May 5th, 2009 08:04 AM
kb vacuum line size RyanGT 99-04 5 November 5th, 2008 07:10 PM
EGR vacuum line? 92sspnotchback 5.0 Mustangs 1 June 12th, 2008 12:18 AM
Vacuum line koda 279 Classic Mustangs 11 September 15th, 2007 04:19 PM
vacuum line 96gtponyred 96-98 1 July 22nd, 2007 12:56 PM
