mass air meter question
Old May 11th, 2009, 08:26 PM   #1
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
I recently converted my car to mass air with an a9l and a mass air meter out of v6 taraus or sable i think. I read on a write up what mass air meter's work and the numbers on the top of it were correct meaning it should work. Also my friend use's the same mass air meter on his car with no problems. Anyways' since I've done the conversion my car devloped a problem where it runs mega lean where withing 10 min of running my headers are glowing red. Should I purchase an acutal foxbody mass air even though everybody say this one should be fine? I've narrowed it down to either the mass air meter or 02 sensors.
spray and pray
Old May 11th, 2009, 09:48 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Red headers is not lean. Its either pig rich or the timing is off.
Old May 11th, 2009, 11:03 PM   #3
1987 ford mustang gt
well see when shes done
My bet is timing i had the same problem... and it was the timing...
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old May 11th, 2009, 11:35 PM   #4
1986 mustang gt
1fst5.0 is on a distinguished road
can u smell unburned fuel?
Threads Similar to: mass air meter question
Mass air meter cobrarob 4V / SVT 1 April 9th, 2008 10:26 PM
I Need To Know (Mass Air Meter Kits) conrad 5.0 Mustangs 5 November 26th, 2007 01:53 PM
Mass Air Meter Euroeater95 94-95 7 November 16th, 2007 04:00 PM
MAF mass air meter neckbonekat 99-04 6 February 22nd, 2007 09:58 AM
Mass Air Meter Question (Cobra 70mm) Help cobraetti 5.0 Mustangs 0 October 30th, 2006 05:52 PM
