afr heads - Page 3
Old May 13th, 2009, 03:15 PM   #41
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by blue90lx View Post
Thanks, i've put alot of hard work into this car its nice to be complimented every once and a while. But i want a set of heads just couldn't afford them. And i still like the afrs cause i've seen them perform at the track and i haven't seen the trickflows perform. What vavles are in the trick flow heads and how much lift are the springs good for?
I like seeing combinations like this that make people's jaws drop. What's sad is there are alot of heads/cam/intake Mustangs out there running 12.80s and people are happy with that. Its really sad considering guys like you can make a stock E7 head and one of the worst cams known to man perform this good. Keep up the good work!
The Twisted wedge heads come with 2.02/1.60 valves and various port sizes including 170cc, 185cc, 190cc and 205cc. I think the springs are good to .540 lift but I don't know for sure. I never run springs that come on the heads, I always use what the cam manufacturer recomends. Trick Flow versus AFR isn't even a comparison. Trick Flow heads do the talking with performance, not with bandwagon internet fools that don't have any experience with the subject matter at hand. Look at Pure Stock on this site. He has gone 10.59 with all off the shelf parts on a stock shortblock in a 2900 pound car.....with a third pedal. Everything he has from the Twisted Wedge heads to the cam to the intake can be bought out of a Summit catalog. However he will not release the details of the cam as of yet but swears it is an off the shelf piece. The car flat out flies and makes 370rwhp and by no means is a gutted race car, not in my book anyway.
Old May 13th, 2009, 04:01 PM   #42
baine21225's Avatar
what is the difference in the fast as cast CNC ported vs the regular CNC ported
"Whip out your dick you'll either get it sucked or get smacked..."
Old May 13th, 2009, 04:10 PM   #43
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The fast as cast are a cast 190cc runner and the CNC heads have CNC'd ports.
Old May 13th, 2009, 05:30 PM   #44
baine21225's Avatar
are they both 190?
Old May 13th, 2009, 07:02 PM   #45
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
are they both 190?
CNC versions are 185 and 205.
Old May 13th, 2009, 07:05 PM   #46
91 LX
13.7@101
what is better? CNC ports or the fast as cast?
Old May 13th, 2009, 07:34 PM   #47
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The 185CNC head flow more. The 190cc fast as cast heads are designed as a cheaper alternative to the CNC heads. They flow slightly less than the CNC heads.
Old May 13th, 2009, 07:36 PM   #48
91 LX
13.7@101
ok gotcha
Old May 13th, 2009, 08:04 PM   #49
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
What would it cost to send TF TW out of the box heads to get CNC'd? Is that more reasonable than selling what you got then buying new CNC'd heads? I have the N-61 cam, what would be a good number to have them ported to: 185, 190, 195, 205? If that makes any sense...
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 13th, 2009, 08:19 PM   #50
baine21225's Avatar
That being the case, should i spend the extra cake for the CNC 205s or get the cast 190s for my s trim setup?
Old May 13th, 2009, 08:21 PM   #51
1988 GT
If you have the money to spend, I would say CNC's if they'll fit the rest of your set-up
Old May 13th, 2009, 10:58 PM   #52
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
You could always get some TFS heads from T.E.A.
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old May 13th, 2009, 11:41 PM   #53
baine21225's Avatar
tea?
Old May 14th, 2009, 12:03 AM   #54
1987 ford mustang gt
well see when shes done
Total engine airflow..
347, torn apart again.
Old May 14th, 2009, 12:35 AM   #55
The Razor's Edge
White Thunder's Avatar
baine why wouldnt you want the heads that flow more?
founder of the FTN Club
Old May 14th, 2009, 12:57 PM   #56
1989 Mustang Gt
tea?
Total Engine Airflow
I love pink
Old May 14th, 2009, 02:24 PM   #57
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Call Total Engine Airflow and find out.
Old May 14th, 2009, 02:25 PM   #58
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Owned by Trick Flow which is owned by Summit.
Old May 14th, 2009, 02:30 PM   #59
baine21225's Avatar
....duh....brain fart
Old May 14th, 2009, 06:47 PM   #60
1988 GT
Threads Similar to: afr heads
GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s BillR1970 Parts 8 May 12th, 2009 10:01 PM
AFR heads 93hatch 5.0 Mustangs 61 October 9th, 2008 12:44 PM
AFR Heads flamed 98 gt 5.0 Mustangs 17 June 19th, 2008 07:23 PM
AFR Heads javier351lx 5.0 Mustangs 4 July 10th, 2007 10:13 AM
Afr Heads javier351lx 5.0 Mustangs 9 July 7th, 2007 07:02 AM
