#101 |
I often wonder the same thing. I also often wonder why nobody ever makes an apples to apples comparison with the Trick Flow Vs. AFR debate.
#102 |
The Razor's Edge
whats worse darrell? the TF vs AFR or 331 vs 347?
#103 |
I think its a toss up because both arguements are full of misinformation.
#104 |
no shit guys..when i get my car back i will post the dyno sheet and put my time slips from the track on here as well. hopefully i can make my goal numbers.....assuming my "mechanic" put it back together right....and i believe the head test was between the afr 165, (they also had the 185 in there) and the 160 standard tf track heat heads among others ie. FRPP,Edelbrock,holley etc.....
By the way...my deciding factor on the AFR heads was the crazy amount of people i talked to at the recent 45th annisversary of the mustang in birmingham AL..almost everyone i talked to liked either TF of the AFR...more so in my opnion towards the AFR...so thats what i went with...i knew what flow rates i was looking for and combustion/exhaust size etc, but was looking for a brand to trust. again, i would be happy with either, but prefer the afr's as of now....
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
#105 |
The Razor's Edge
upgrade the spring to match your cam specs....
#106 | |
I'm curious as to what they like better about the AFR heads and what details made you make the decision that AFR is a better head.
#107 |
well then how about this, what do you think of TW vs Canfield
i still think i'd lean toward TW
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#108 |
1988 GT
Is BRODIX anywhere in the mix here? Just figured since it's pretty clear the original question was answered and we're throwing around other companies now...
#109 |
1990 LX hatch
Side note. I have spent the past 2 days reading everything I can on heads, and everything that goes with them.
Every aspect except a few, like chamber size, leads to peak, and average flow. Cross section, average, and minimum, are directly related to flow. Valve location, and size, and angle is related to flow. Combustion chambers valve shrouding area, port location, are all related to flow. Velosity is another grey area, I have found no real numbers, or standards. Just things like "good velosity". Port finish is not as important, as the wall of the ports allways have no flow. It seems the standard "xxx. cc runners", should be replaced with "minimum cross section", as that is a better number to go off of. Bit in short it all seems to add up to flow.
#110 |
1990 Mustang gt
If you haven't already, go to SBFtech.com. It's full of great info from peeps like jay allen. I read alot on there and feel like a complete dumbass when I do. Still kinda confused about cross section.
2002 gt 5-speed slow 1990 gt 5-speed junk |
#111 |
1990 LX hatch
its a 2d representation of the port area, measured in square inches.
#112 |
Canfield for sure....my opinion anyway. The Canfield is very similar to a High Port.
#113 | ||
There is alot of good info there and alot of geniuses in the field.
#114 | |
1990 LX hatch
Sorry, I was refering to polishing, as the finish. ur r correct tho. a good casting will flow better than an extremely rough one. The source I found, got less than 1% increase flow, from polishing the runners.
Threads Similar to: afr heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 09:01 PM |
| AFR heads | 93hatch | 5.0 Mustangs | 61 | October 9th, 2008 11:44 AM |
| AFR Heads | flamed 98 gt | 5.0 Mustangs | 17 | June 19th, 2008 06:23 PM |
| AFR Heads | javier351lx | 5.0 Mustangs | 4 | July 10th, 2007 09:13 AM |
| Afr Heads | javier351lx | 5.0 Mustangs | 9 | July 7th, 2007 06:02 AM |
