what next? ???
Old May 11th, 2009, 11:43 PM   #1
bluekarta is on a distinguished road
what next? ???
Ok heres the deal im starting my research on the stangs next power boost, i feel ive just about maxed out the potentail for a N/a 302 block with out spending big dollor prices on parts...as of right now im looking at three roads, 1) supercharging 2) 347 stroker 3) turbo
i was hoping to get input on what way to go, what i will need that i don't have to support them, what kinda power and times u feel i could run, also the pros and cons of each application. My budget is about 3k.
Thanx in advance for the info, Ryan
94gt (Teal) ported gt40x heads, Port matched eddy intake,Steeda #19cam, 1.7 ratio rocker arms, 4.10 rears, 30lb injectors with c&l mass air, 75mm t-body, 190 fuel pump, And a NOS big shot system (100 shot jetting)
Old May 12th, 2009, 12:16 AM   #2
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
well if your just deciding between those turbo best then supercharger and then stroker....if thats all your doin
just a stroker kit isnt goin to add a whole lota power.....what heads you running
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old May 12th, 2009, 08:44 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Blower or turbo. Your heads and intake are too small for a 302 so they are surely going to choke a 347. You would need to make a cam change for a 347 as well. You could put all of those parts on a 347 but it wouldn't make much more (if any more) horsepower than your 302 is making. It would make more torque but it would be out of steam at a low rpm and similar built 302s would be driving around you. 302 parts make 302 horsepower.
Old May 12th, 2009, 09:34 AM   #4
flamestang's Avatar
flamestang is on a distinguished road
Is this a street strip car.
Old May 12th, 2009, 10:00 AM   #5
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
3K I say blower w/ tune...
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 12th, 2009, 11:42 AM   #6
a street car with some bite is what im going for...
i like the blower idiea, but what kinda supporting mods would i need that i don't have right now ? what numbers can i make safly on a 100k seasoned block? what brands do you recomend?
As for the 347 route i know that i won't make the numbers i could with the forced induction but if i were to go to some nicer heads and a custome cam where would u say i could get to as far as power. I like this idea beceause of the fact i would over haul the bottom end in the process.
Imput ?
Old May 12th, 2009, 11:46 AM   #7
Gt40x heads that have a little porte and pollish on them
Old May 12th, 2009, 12:07 PM   #8
91 LX
13.7@101
if i were you....i would freshen up the bottom end...maybe buy some lower compression pistons, sell your n20 kit, buy an used SC wiht 10-15 lbs of boost (im not an expert on the trims, etc), 42 lb injectors, 255lph fuel pump, and a dyno tune so then you dont have to change your MAF and you will make good power
Old May 12th, 2009, 12:32 PM   #9
flamestang's Avatar
with 3K and what you have and the fact that you seem to want boost you could safely run a Paxton 1000 kit with 6-8 psi.when you build a stronger motor you could change up pulleys for more boost.sell the nitrous kit to add funds.get it dyno tuned and have fun with it!your 30# inj should work good you may need a 255 fuel pump.
Old May 12th, 2009, 02:31 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Imput ?
You are limited to about 500hp no matter what route you go. The block is the weak link. It won't matter if you keep the lower end stock or stroke it, 500hp is about what it is safe for.
A 347 with better head, cam and intake would make a boat load more power than what you currently have but you won't be able to do it with your $3000 budget. If you do some shopping around for some used heads you might be able to do it. I figure your current heads and intake you could probably turn for $800-$1000 so that gives you about $3800-$4000 to work with.
Old May 12th, 2009, 06:42 PM   #11
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
1500-1700 for a v1 s-trim or a v2 s-trim
80 give or take for a 90mm 03 cobra or lightning maf
150+ if you go used for some 42lb injectors
350-400 tune
250 chip
Call it a day. Get a kit with a power pipe... not that washer/dryer flex pipe bs. Also a metal bypass valve, those bosh's get old and you'll have air going back and hitting the blower.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
