LinkBack (4) | Thread Tools |
#1
fuel injector question
Im wondering if i can find bigger injectors at the junk yard that will fit my stang. My stock ones are #19 correct? What about 5.0 explorers with the gt40p parts? will those be bigger than my stock ones? I got the gt40p intake and heads off an explorer and im wondering if the injectors from that vehicle will be bigger and fit my stock 93 5.0. and will my stock fuel rail work on the gt40p intake or do i need to go back to the yard and grab the fuel rail off the explorer?
+1 to the injector chart.
The Mustang fuel rail will fit the Explorer intake.
1988 GT
Thats a nice chart Ryan... Good info
no problem man.
thanks alot. that helps a ton. Im gunna look for the 24 pound injectors from the ford trucks. Are the #24 found on F-150,F-250,F-350's or what? or should I just look for white injectors on any F series truck's?
Ford 19lb injectors (high impedance) #s: E5TE, D5B, F78E, F6VE
96+ Explorer 5.0 has better 19's than Mustangs Ford 21lb injectors (high) #s: D9B, F65E (305/350 GM) Ford 22lb injectors (high) #s: FOTE-D9B (vetts and range rovers) Ford 23lb injectors (high) #s: F7TE, F8TE (7.5L truck) Ford 24lb injectors (high) #s: F5DE, F1TZ, F2LE, F2LE-9F593-B2A, FMS-M-9593-A302 Ford 24lb injectors Ford 93-95 Mustang Cobra Ford 24lb injectors 93-01 Lincoln Mark 8 Ford 24lb injectors other DOHC 4.6 Ford 24lb injectors 88-97 EFI 460's F250-450 & E250-450 Ford 24lb injectors Lincoln Aviator w/4v 4.6 Ford 24lb injectors Lincoln Navigator w/4v 5.4 26lb '00 LS1 F body, maybe '99 to?, same as Ford 24's Ford 30lb injectors (high) #s: E9SE, F1SE, F1SE-E1A (3.8SC and SuperCoupes) Ford 30lb injectors: 95/96 Ford 4.0L Explorer & Ranger & Other Ford 30lb injectors: 89-93 SuperCoupe Ford 36lb injectors: 94-95 SuperCoupe Ford 39lb 03-04 Cobra Ford 42lb 99+ Lightning Taurus SVO some years had 24s some had 30s |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/123058-fuel-injector-question.html
| tpi injectors - Chevelle Tech | This thread | Refback | October 25th, 2011 08:54 PM | |
| tpi injectors - Chevelle Tech | This thread | Refback | October 25th, 2011 03:34 AM | |
| Ford Fuel Injector Size Chart - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | May 16th, 2010 09:48 PM | |
| Everything about gmc syclone - Yahoo! Glue | This thread | Refback | May 14th, 2009 08:26 AM | |
Threads Similar to: fuel injector question
| fuel injector | Stang Tech | V6 Mustangs | 15 | May 6th, 2009 06:45 PM |
| Lucas fuel injector cleaner and fuel filter | Saleen0101 | Modular Mustangs | 0 | September 25th, 2007 03:09 PM |
| Another fuel injector question.. | One Bad Sixxx | V6 Mustangs | 48 | June 25th, 2007 07:47 AM |
| Fuel Injector PSI Question | 2much4u | 99-04 | 8 | September 27th, 2006 12:33 AM |
| Fuel Injector sizes without regulators or fuel pumps | streetstang06 | 96-98 | 15 | February 26th, 2006 10:02 PM |
