Two questions-carb and compression
1) why is my carbs bufferfly vavle sitting like this? Car is off, nobody is touchging the throttle...
![]() 2) what is the standard compression on a 9.0:1 302? in psi or kPa |
#2 | |
2- Compression ratio and cranking compression are two different things.
#3 | |
also, i was running the stock headers and Y pipe, cut off riht before the second cats (im still building the car) and when i took it above 4000 rpm id get crzy backfiring and it felt like it lost power. Am getting a lean out backfire? If so how do i fix it? (i had some fuel leaks before, but i replaced the lines, and havent had a chance to run the car yet) could it be carburator jetting? |
#4 | |
120psi roughly and each cylinder should be within 10% of the highest cylinder.
btw my fuel pressure gauge byt eh car is reading 4spi at idle...isnt this a bit high?
Mechanical or electric fuel pump?
its a mech pump
carbs like 6-7 pounds of fuel pressure.
weeee foooord!
Does the pressure increase with rpm? 4psi is definitely not too much fuel pressure, it is more along the lines of too little fuel pressure. You should see 7psi.
ill have to get ym dad to look at the gauge as i rev it. how do i go about bumping the fuel pressure on this?
you need a higher volume pump and a regulator set to 7 psi.
weeee foooord!
do i absolutely need a higher volume pump? Cant i jsut get a regulator? im sure tons of guys can support modest horsepower on a stock v8 pump..
You might need a new stock pump. Does the pressure goe up with rpm?
yeah the pressure goes up, was at 5 spi at 2000 rpm
also, when i fire it up, even if i keep it at 2000 rpm, when the eienge is cold it sounds liek tis running on 6 or 7 cyl only, but sosudns fine ocne warm... just looked at the backup fuel pump spec sheet and it says it supplies up to 6.5psi only... Last edited by PolishSasquatch; May 13th, 2009 at 10:24 PM. |
well i fired it up today, and noticed the fuel pressure was at 5.5 at idle...?
Threads Similar to: Two questions-carb and compression
| 5.0 will have 11.0 compression | DarkCandy08GT | 2005 - 2010 | 70 | February 7th, 2009 09:08 PM |
| more fuel inj to carb questions | Speedstang302 | 5.0 Mustangs | 56 | January 23rd, 2009 08:33 AM |
| compression questions | mustangsoldier | 5.0 Mustangs | 46 | January 7th, 2009 07:51 PM |
| Swapping from EFI to carb questions | Speedstang302 | 5.0 Mustangs | 31 | March 5th, 2008 07:15 PM |
| compression? | bigyam21 | 96-98 | 2 | January 21st, 2008 01:12 PM |
