351w bored .40 over
Old May 12th, 2009, 06:24 PM   #1
1993 mustang hatch back
sctravis77 is on a distinguished road
Send a message via AIM to sctravis77
351w bored .40 over
Will i feel much of a difference if i had my 351W bored .40 over? Im trying to figure out what i want to do. My buddy has a 302 that was just rebuilt that he said he would sell me for $200 but im not sure what to do. The only other mods i have on my 351W now is long tubes and edelbrock intake and a wolverine cam.
Old May 12th, 2009, 06:31 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No, you won't notice anything from an overbore, unless the engine is in bad shape. You are only gaining 7 cubic inches boring a 351 .040. You don't bore engines for big power gains, you bore them to have a clean and true cylinder to work with.
What are your goals here?
Old May 12th, 2009, 06:41 PM   #3
351w
I want something with some power but i would like to be able to drive it. I live in South Carolina so id like to be able to drive to the beach in it. (2 Hr Drive) I want more of a stop light to stop light quickness. I dont care if it can go 120mph. Thats not important.
Old May 12th, 2009, 06:48 PM   #4
The Razor's Edge
White Thunder's Avatar
stroke it....or keep it 351 get some heads intake and cam....
id consider a comp test
founder of the FTN Club
Old May 12th, 2009, 07:25 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Heads, cam and intake. A well matched combination will turn it into a rocket on the street.
Old May 12th, 2009, 08:09 PM   #6
My Intake i have is a Edlebrock Performer RPM, DOOE-C heads from a 69 mustang and my cam is rated at .512 of lift with 222 duration on the intake and .534 with 232 duration on the exhaust. The heads and Cam i havent put in yet though.
Old May 12th, 2009, 08:55 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
How much money do you have to work with. I wouldn't use those heads. I'm not sure that cam is going to help you either. I'm assuming its a hydraulic flat tappet?
Old May 12th, 2009, 09:03 PM   #8
Yeah it is. I have about 1000 to work with. Is that cam too much for that motor?
Old May 12th, 2009, 09:05 PM   #9
crd89stang is on a distinguished road
have the heads you have been freshened up? if not just buy some good heads trick flow etc the money you would spend to freshen those old heads would be better spent in good heads. cam is kinda on the small side. .040 not going to increase power un less it has blowby now and needs to be bored
Old May 12th, 2009, 09:12 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That cam is better than a stock 351W cam but not optimal. Given the dollar figure and goals, I'd look for a set of used aftermarket aluminum heads and a set of pushrods and rocker arms. Then you can use that cam that you already have. You should be able to make around 400hp with it.
Old May 12th, 2009, 09:13 PM   #11
The Razor's Edge
copy cat
Old May 12th, 2009, 09:27 PM   #12
Would i be better off just getting that 302 for 200 and selling my 351 then id have 1000 plus what ever i sell my 351 for. A buddy said he might want it and would give me 400 for my 351
Old May 12th, 2009, 09:39 PM   #13
351 is stronger and will make more power. what do you already have for parts headers intake dist?
Old May 12th, 2009, 09:45 PM   #14
The Razor's Edge
351 is better......the block holds about 200 more horse power and can make it easier....there is no replacement for displacement
Old May 12th, 2009, 09:48 PM   #15
Everything is stock on that 351w except the intake which is that performer rpm. I have a Mallory Distributor and the ford racing oil pan for the 302 that was given to me thanks a friend that was deploying overseas.
Old May 12th, 2009, 10:50 PM   #16
The Razor's Edge
get a compression test...should be around 150 psi
Old May 12th, 2009, 11:17 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Only if you want to make less horsepower.
Old May 13th, 2009, 02:22 PM   #18
ryans88gt's Avatar
spend the 1000 bucks on a used vortech s-trim
Threads Similar to: 351w bored .40 over
351W with C4 MustangMatt96GT 5.0 Mustangs 7 April 2nd, 2009 11:46 PM
351w? whiteboycustom 5.0 Mustangs 8 March 25th, 2008 02:05 PM
351w djh1286 94-95 2 February 25th, 2008 08:17 PM
351w notsoslow50 5.0 Mustangs 9 October 8th, 2007 06:22 PM
351w javier351lx General Tech 0 May 13th, 2007 04:46 PM
