Mustang idle surge and base idle reset - Page 2
LinkBack (27) Thread Tools
Old March 19th, 2010, 01:59 AM   #21
Look Ma! My First Post!
chrisb24 is on a distinguished road
88 mustang gt 5.0 HO
I have a 1988 ford mustang GT with the 5.0 HO motor with cold air intake . When acceleratin the throtle the car popps and lugs but when I get the car out on the open road at around 65 to 70 mph the car smooths out and does not popp nor does it lug what could be the problem???
Old March 19th, 2010, 03:53 AM   #22
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
lean mixture
Old March 22nd, 2010, 08:01 PM   #23
1988 Mustang LX Convt.
not sure@sometime after 85
88stanglx is on a distinguished road
Send a message via AIM to 88stanglx
Also, when i had that problem with my 88, it ended up being the diode on the ICU harness right before the distributor. Some people call it the lego but i ended up pulling that off and now it runs fine, i just have to find a new one. Also another common cause, which some people overlook, is loose battery cable connections or a bad battery. If not enough energry is getting to the computer and the alternator cant supply enough energy to everything the idle will be effected.
Old April 24th, 2010, 11:56 PM   #24
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
Originally Posted by ddarkslayer View Post
I can't even start up my car with the IAC unplugged
mine will start then die immediately with the IAC unplugged.
Old April 25th, 2010, 05:48 AM   #25
1988 Mustang 5.0 LX
12.48@118.27
I just solved my problem. If you try to start up the motor with the IAC off and it wont start up, try starting the motor up and disconnecting the IAC motor when the motor is running and warmed up. if its in the range of 550 rpm then you need to turn the idle screw up to 600, 700 RPM. Shut the motor of and disconnect the negative terminal of the battery for a minute. Plug it back in with the IAC disconnected. It should start up with no problems what-so-ever. Start checking the TPS and you want to get a spec of .88 through 1.0 volt. when I checked mine after turning the Idle screw it was 1.2 so I had to drop it.
So the biggest thing was that the throttle blades where completely closed and the IAC was working to hard and couldn't keep up and not to mention that the TPS was out of range.
The idle surge symptoms happen once the motor warms up
Old April 25th, 2010, 06:21 AM   #26
The Big Spoon
never fast enough
Word, I bet that is the same issue with mine!!! I think the screw is all the way backed out... thanks for shedding the light.
Old April 26th, 2010, 12:35 AM   #27
1988 Mustang 5.0 LX
12.48@118.27
I know if I didn't no body would
Old May 7th, 2010, 09:02 PM   #28
895.sloGT's Avatar
1989 Mustang GT
14.1
895.sloGT is on a distinguished road
hey i tried all of this but im still getting the surge however i noticed that if i pump the brake the surge goes away. is that a vacuum leak and if it is will the leak cause the surge? thanks
"Whether you think you can or think you can't - you are right." ~Henry Ford and I think my car will eventualy hit 10's
Old May 8th, 2010, 08:35 PM   #29
The Big Spoon
never fast enough
cap off the line going to the brake booster and try it again. Many times the little vacuum manifold on the drivers side above the brake booster gets cracked and will leak.
Old May 8th, 2010, 09:58 PM   #30
895.sloGT's Avatar
1989 Mustang GT
14.1
thanks ill give it a try
Old May 20th, 2010, 11:08 PM   #31
holset35's Avatar
1986 LX NOTCH
holset35 is on a distinguished road
TPS get a new one to just check it then take it back
Old June 30th, 2010, 03:55 PM   #32
fogged306's Avatar
89 GT
Originally Posted by 1slo5.0 View Post
The TPS is located directly on top of the throttle body and is adjusted by loosening the two phillips mounting screws and swiveling the sensor until the highest reading is found. It may be necessary to elongate the holes with a small drill bit or small file to achieve the desired reading. The spec range for Key On is from .88 to 1.0 volt; shoot for the .90 to .98 volt. Make sure voltage reaches/exceeds 2.71v at WOT.
Just a correction on this part. The TPS min-max values with the throttle plate closed are between .5V and 1.19V. Anywhere in between there and your TPS sensor is fine. At WOT, you want to be 2.71V above your value with the throttle plate closed.
Example: if you have a value of .87V with the throttle plate closed, you need a value of 3.58V or greater at WOT.
Old July 21st, 2010, 10:47 PM   #33
jcftw is on a distinguished road
Thanks for the info. New here and this is just the kind of stuff I'm looking for.
Old August 8th, 2010, 10:14 PM   #34
1987 Mustang Coupe
Squires67 is on a distinguished road
Hello out there
I am having a problem fith my 5.0 and looking for a lil help
The stang has been sitting for about 2 yrs occasionally getting started ive just recently had the time and $ to get it back out
it starts fine but surges while at idle im pretty sure thats a sensor but when i rev it up it sounds like it loaded up and smokes black smoke
it has an electric fuel pump on it and when you turn it off it clears up and runs fine. Could the fuel pump be flooding it out? and if so it is the same pump that has been on it for the last 5 yrs why would it start doing that?
Old August 12th, 2010, 02:56 PM   #35
khern1's Avatar
1988 ford mustang GT 5.0
khern1 is on a distinguished road
hey guys i did this and i backed the idle screw back and nothing happened its still idleing at 1000rpm and i backed the idle screw all the way out to the point where i just took it off lol and its still at 1000rpm tell me what u think guys
Old September 13th, 2010, 01:37 PM   #36
1NVERTED5.0 is on a distinguished road
TPS
1990 Mustang 5.0 Vert'
2009 Nissan GTR
Old October 6th, 2010, 01:27 AM   #37
moneymo's Avatar
1991 Mustang Gt 5.0
moneymo is on a distinguished road
Thanks for this info. I took my EGR off and bored my engine and put a mild cam on it. It started idling low but would seem as if it were about to turn off and sometimes does when im on a red light so i constanly give it gas. Im thinking the underdrive pulleys are killing the stock alternator. Could the same adjustments help my idle problem @1slo5.0
Old October 6th, 2010, 01:33 AM   #38
moneymo's Avatar
1991 Mustang Gt 5.0
Old November 9th, 2010, 01:00 PM   #39
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
brimmer555 is on a distinguished road
My 89 GT starts alittle weak at first and I have noticed the battery gauge is low when I start it up and it always idles for a minute and then dies. but if i rev it a bit and then go and it has been running for a little while the battery gauge is in the middle and it doesn't try to stall at all.
I think something is draining the battery while it sits because I have this problem every time I start it up, if it hasn't been running for a while.
I have no clue what could be draining it though?
Old December 9th, 2010, 12:11 AM   #40
brimmer555's Avatar
1989 Mustang GT
Tell ya next year
Idle issues are common on these cars, especially 5-speed cars. EGR Valves, Idle Air Bypass solenoids and Throttle Position Sensors are common causes. A bad connection with the 10 pin (salt and pepper shakers) black and white engine electrical connectors can also cause poor idle quality. To ensure a good connection on the 10 pin connectors a little modification can be done which is fairly easy and will cure some surging and hanging idle issues on 86-93 Mustangs and should be the first thing done when tackling any idle issues.
10 Pin Connector modification:
1. Take the 10 pin connectors apart (salt and pepper shakers).
2. use a pick like tool to spread the male terminals open more so they make better contact. In the center of each male terminal there is a small seam and seams down the sides of the terminal which allows you to spread them open.
3. Apply some dielectric grease to the terminals
4. Plug the connectors back in.
Throttle Position Sensor (TPS) adjustment:
Without the proper adjustment, the throttle position sensor (TPS) will give the computer false reading as to the exact throttle opening. A false reading will limit wide open throttle performance. A voltage reading must be taken using a digital volt/ohmmeter (DVOM) with the Key On/Engine Off and with the Key On/Engine Running.
Incorrect Throttle Position Sensor (TPS) voltage will result in reduced performance including a possible hanging/surging idle. The best way to take a TPS voltage reading is by using two safety pins through the wires coming from the sensor. The positive lead is attached to the green wire, while the negative goes to the black wire. Always ground the meter through the sensor's black wire. This gives a direct, and more
accurate ground into the computer.
Resetting the base idle:
Clear the computer's idle memory by disconnecting the battery for 20+ minutes.
-Disconnect the Idle Air Bypass solenoid
-Reconnect battery
-Start engine and set idle speed to desired RPM with idle screw on throttle body
-Turn off engine and reconnect the air bypass solenoid
-Set TPS voltage between 0.90 - 0.95 volts with a digital volt meter
-Start engine and let it idle for 2 minutes with no accessories on.
-Turn off engine for two minutes
-Start engine again and run for 2 minutes with every accessory turned on.
-Turn engine off again.
Thanks for the great info!!!!!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/123164-mustang-idle-surge-base-idle-reset.html
turbo mustang wont idle This thread Refback November 1st, 2011 01:32 PM
EFI idle question - ClassicBroncos.com Forums This thread Refback September 5th, 2011 01:51 AM
TPS reading at 4.98 volts! Why??? - Ford Mustang Forums This thread Refback March 22nd, 2011 02:17 AM
Service Engine Light - Northern California Ford Owners  This thread Refback February 25th, 2011 07:33 PM
New IAC, need to get it working - Ford Mustang Forums This thread Refback January 9th, 2011 12:36 PM
RPM trouble ???? - Northern California Ford Owners  This thread Refback January 6th, 2011 11:32 PM
TurboFord.org Forums: Base Idle setup This thread Refback December 14th, 2010 09:06 AM
TurboFord.org Forums: Base Idle setup This thread Refback December 14th, 2010 03:15 AM
Monster Problem!: Grassroots Motorsports forum: Grassroots Motorsports Magazine This thread Refback November 1st, 2010 11:55 AM
WTT - Carb for EFI - Page 2 - Tampa Racing This thread Refback August 21st, 2010 11:55 PM
Saleen Club of America SCOA Talk • View topic - 89 Stalling Issue - Need some help This thread Refback June 1st, 2010 01:01 PM
EFI- Help! - FFCars.com - Factory Five Racing Discussion Forum This thread Refback May 15th, 2010 08:50 AM
Idle Surge Mustang 5 0 - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback May 8th, 2010 12:35 PM
turbo mustang wont idle This thread Refback April 24th, 2010 12:11 AM
turbo mustang wont idle This thread Refback April 23rd, 2010 10:46 PM
Finally got my supercharger kit installed This thread Refback March 22nd, 2010 09:11 PM
Finally got my supercharger kit installed This thread Refback March 22nd, 2010 05:34 PM
Finally got my supercharger kit installed This thread Refback March 22nd, 2010 03:48 PM
Finally got my supercharger kit installed This thread Refback March 22nd, 2010 03:46 PM
Finally got my supercharger kit installed This thread Refback March 22nd, 2010 03:23 PM
Surging??? - Northern California Ford Owners  This thread Refback March 12th, 2010 04:46 PM
Surging??? - Northern California Ford Owners  This thread Refback January 10th, 2010 09:09 PM
Surging??? - Northern California Ford Owners  This thread Refback January 10th, 2010 08:59 PM
I NEED HELP!!!!!!!!!!! This thread Refback August 24th, 2009 02:18 AM
5.0 Trickflow intake question - Street Car Forums - auto forum uniting car and race enthusiast everywhere! This thread Refback June 3rd, 2009 10:15 AM
5.0 Trickflow intake question - Street Car Forums - auto forum uniting car and race enthusiast everywhere! This thread Refback June 2nd, 2009 11:07 PM
1990 Mustang Throttle Position Senor Voltage Output Wire on Kosmix This thread Refback May 14th, 2009 05:57 PM
Threads Similar to: Mustang idle surge and base idle reset
Idle reset question fateisajester 5.0 Mustangs 4 May 15th, 2009 01:49 PM
Mustang 5.0 Idle surge ddarkslayer 5.0 Mustangs 21 May 15th, 2009 01:29 PM
5.0 Base Idle Reset TurboLX 5.0 Mustangs 26 May 9th, 2009 12:02 PM
Idle surge izze01 5.0 Mustangs 1 July 1st, 2007 02:32 AM
idle surge slow98gt 96-98 8 February 12th, 2007 04:56 PM
