1993 Mustang lx coupe
1.7 crane rockers with E303 on 302 stock pistons any issues?
I have 1.6 roller rockers on there now but am getting a set of lightly used 1.7 cranes from a buddy. Will there be any issue botling these on in place of the 1.6 with the e303 cam. Learning as i go here....first real mustang! Older mustang was a v6.....alot different. I know i might have to take off the underside of the valve covers or buy new ones for clearance. Any troubles you guys can think of.....is it worth it to change from 1.6 to 1.7 both roller rockers. Will i notice a difference. thanks for the input
What springs are you running? Whats is your coil bind clearance minus peak lift minus installed height?
PeteAndersonRacing.com |
85 GT/86 SVO/2010 GT500
I have set that up twice with no problems.You will be fine
#5 | |
Valve to piston clearance shouldn't be an issue but coil bind and/or valve float might be. Probably not worth it in this case.
The crane 1.7s will give you a 30thousands more lift. So the e-cam has .498 lift when you add the 1.7s it will give you a .528 lift no issues with clearance just might want to get some different valve springs
to many parts and money to be so slow
1990 LX hatch
.542 is the end of the line for safe PTV with stock stuff. But its ALLWAYS recomended to check
1992 Lx
11.39@119.24
isnt e cam 510 lift on both sides?
1990 LX hatch
no. not unless the lobes are really dirty.
#10 | |
![]() E cam: .498 / 1.6 = .31125 lobe lift .31125 x 1.7 = .529 lift at the valve Trick Flow 51420001 .542 / 1.6 = .33875 intake lobe lift .33875 x 1.7 = .576 intake valve lift .563 / 1.6 = .351875 exhaust lobe lift .351875 x 1.7 = .598 exhaust valve lift
Depending on the valve timing of the cam and factory machining tolerances. Valve timing can play a bigger role than the actual valve lift.
thanks for all the responses guys.
#13 | |
1988 GT
Also, when did the name change happen, I just noticed that.
![]() Last edited by 88-gt-t-top; May 13th, 2009 at 07:40 PM. |
What a horrible statement..........
1990 LX hatch
Straight from FMS svo catalog from 1995. As the thread topic is about rocker ratio, which has nothing to do with duration.
Stop reading magazines sir
#17 | |
Couple days ago.....finally.
Threads Similar to: 1.7 crane rockers with E303 on 302 stock pistons any issues?
| gt-40 heads w/ stock e7 rockers? | 91cobra5.0 | 5.0 Mustangs | 9 | November 2nd, 2008 01:57 PM |
| Weight of Dart sportsman 302 compared to stock 302 | painfully slow | 5.0 Mustangs | 3 | February 23rd, 2007 04:47 PM |
