coolent hoses
Old May 12th, 2009, 11:57 PM   #1
92hatchback's Avatar
92hatchback is on a distinguished road
coolent hoses
alright so im in the process of removing my heater core (pain in the ass).im finally to the point of removing it but i need to get the coolant hoses off and they wont seem to budge, just wondering if anyone has any tricks to this or do i have to just pull the hell out of it..
Old May 12th, 2009, 11:59 PM   #2
1992 Lx
11.39@119.24
cuz them off then rip them outa the lower intake
Old May 13th, 2009, 12:17 AM   #3
wouldn't that just make it harder? cant see them being easy to replace..
Old May 13th, 2009, 12:22 AM   #4
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
you're trying to get the ones from the lower intake to the firewall off? Just cut them and yank them off the intake like 93 hatch said. You'll run a bypass hose after u get those off. It's actually really easy. took me like 5-10 minutes maybe
Old May 13th, 2009, 12:25 AM   #5
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
cut them short then split them up the middle
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Old May 13th, 2009, 12:50 AM   #6
Stop failing at life.......
PeteAndersonRacing.com
Old May 13th, 2009, 08:34 AM   #7
flamestang's Avatar
flamestang is on a distinguished road
don't cut them if you plann to reuse. hook shape a coat hanger break them free then pull.
Old May 13th, 2009, 09:03 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You don't work on cars much do you? Not to be rude but removing the heater hoses is not complicated. Use a pliers and twist them at the heater core. When you get them broke loose, pull them off. Its that easy. The heater core is relatively easy too. Pull the dash out and R&R the heater core. Install the dash and your done. Its a 2 hour job.
Old May 13th, 2009, 09:51 AM   #9
baine21225's Avatar
2 hours is rollin, but yes is your reusing pliers, twist, remove
Threads Similar to: coolent hoses
Brake hoses Garhfer 99-04 5 June 18th, 2008 11:58 PM
coolent in the cab? wtf? 91cobra5.0 5.0 Mustangs 12 March 3rd, 2008 09:25 AM
hoses. patwrecked Visual 5 April 4th, 2007 04:36 AM
Low coolent light????? lugthug713 94-95 1 January 2nd, 2007 06:50 AM
Vacuum Hoses shade tree 5.0 Mustangs 2 September 9th, 2006 01:03 AM
