Electrical help
Old May 13th, 2009, 10:52 PM   #1
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
Electrical help
I moved my wiring into the inner fender and now I have a problem
when the headlights are on the volt meter drops and does not recover
if I ground the POSITIVE side of one of the corner lights to the body it charges but the fuse blows and I loose the tail lights but the headlights are brighter (found out by accident)
So i tried grounding the - side instead and that did not do anything
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Old May 14th, 2009, 01:20 PM   #2
fakesaleen's Avatar
1988 lx t-top
Really, no one Knows?
Old May 14th, 2009, 01:54 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Obviously a wire is grounding out. I would either pull all of the wiring back out or start doing continuity checks on the headlight wires (if you can find them in the harness). Something is touching where it shouldn't be.....
Old May 14th, 2009, 10:34 PM   #4
fakesaleen's Avatar
1988 lx t-top
thanks, that was the plan I just wish it was easier
Threads Similar to: Electrical help
Help Electrical rusty2407 5.0 Mustangs 5 February 21st, 2009 07:34 PM
Electrical help Muscletang 96-98 5 December 30th, 2008 11:18 AM
electrical help bobb17 2.3 Mustangs 10 February 10th, 2008 11:27 PM
Electrical help... joeice14 2005 - 2010 8 January 30th, 2008 01:34 AM
Need Electrical HELP!!! monkey187 Audio/Video 8 March 19th, 2007 10:41 PM
