e7s vs. windsor heads
Old May 14th, 2009, 12:41 AM   #1
odie22's Avatar
86 Ford Mustang
odie22 is on a distinguished road
i have a question with the e7s and the windsor heads? i would like to know what would be the pros and cons of the E7s vs. the WINDSOR head... thanks for the help
-odie22
Old May 14th, 2009, 12:43 AM   #2
The Razor's Edge
White Thunder's Avatar
you can make more power with a set of 351w heads...but not near as much as a good aftermarket....
founder of the FTN Club
Old May 14th, 2009, 12:56 AM   #3
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
When I was n/a with a cobra intake fcam and p heads. I ran my buddies lx on welds with the same set up except w heads. He pulled a car or so on me only.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 14th, 2009, 12:58 AM   #4
The Razor's Edge
drivers mod? lol jk
Old May 14th, 2009, 01:08 AM   #5
The Razor's Edge
Stan Weiss' - Cylinder Head Flow Data at 28 Inches of Water
stock e7 at .500
159/109
68.6%
63.9/66
189/196
.389/.328
327 hp
355
351w at .500
189/115
60.8%
71.1/61.7
211/183
.373/.271
389 hp
422
474
and
177/142
80.2%
66.6/76.2
197/226
.35/.335
364 hp
395
444
two 351w's out there im sure it goes by year but i dunno
Old May 14th, 2009, 01:16 AM   #6
1993 5.ohhhh
12.97 @140mph
Originally Posted by White Thunder View Post
drivers mod? lol jk
nice lol. On a side note though, just average drivers.
Old May 14th, 2009, 01:18 AM   #7
The Razor's Edge
meh arent we all
Old May 14th, 2009, 01:24 AM   #8
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
I'd throw a set of GT 40 heads on my ride if I were on that tight of a budget. You can get them at every junk yard and all over ebay and craigslist. Cheap heads that will outflow the shit out of an E7. The 351w heads are not worth a damn either. Unless they are like a 70 model or earlier I think. So, you do the math. Spend 200-300 hundred dollars on a set of GT40(p) heads at any junk yard any day of the week or spend days maybe weeks and alot more $ looking for a d0OE head.
Old May 14th, 2009, 01:32 AM   #9
odie22's Avatar
86 Ford Mustang
iam not sure what all of the head codes are i have a set of the windors head ready to go with 1.6 roller rockers. i know my friend ran the autolites 3924 spark plugs if this helps
Old May 14th, 2009, 01:37 AM   #10
1988 Notchback
11.19 @ 122mph N/A
a 3926 is a hotter plug, it's what I run
Old May 14th, 2009, 01:42 AM   #11
odie22's Avatar
86 Ford Mustang
i have nitrous on my car so i need a colder plug
Old May 14th, 2009, 01:46 AM   #12
1988 Notchback
11.19 @ 122mph N/A
<~~~ Runs a 125 shot on his turd with same above mentioned plug. So far so good. I spend more time off the bottle than i do on it, way more time.
Old May 14th, 2009, 01:46 AM   #13
The Razor's Edge
id close the gap some too
Old May 14th, 2009, 03:29 AM   #14
odie22's Avatar
86 Ford Mustang
what would you set the gap to
Old May 14th, 2009, 03:04 PM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
-odie22
This is not even worth discussing. The 69-70 Windsor head is better. All other Windsor heads are junk. GT40P heads are a better option if you are stuck on using a factory head.
Old May 14th, 2009, 04:39 PM   #16
odie22's Avatar
86 Ford Mustang
well sorry for asking ill make sure to google my questions from now on
Old May 14th, 2009, 09:47 PM   #17
The Razor's Edge
i wouldnt close the gap any more than .035 id go somewhere around .040
if your not running nitrious alot i would but a set for when you do...1 step colder gap them to .040 and keep another set, set to factory specs...i think its .055
Old May 15th, 2009, 01:44 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Ok. I'm sure if you look long enough you will find someone that says factory Windsor heads are the best thing since pierced nipples. The facts are that factory Windsor heads suck. The 69-70 (and maybe the 71) heads are ok but still not a GT40 head. All of the rest of the 351W heads are identical to the 302 heads except for the differnce in head bold hole diameter. 302 is 7/16 and 351W is 1/2. A 351W head requires a reducer bushing when used on a 302. As far as Pros and cons go, there are no pros to any 351W head other than the ones I listed. The only pro of an E7 head is it is better than the 351W heads (except the 69-70 C9-DO heads). The cons for both the 351W aned E7 heads are lengthy. Poor flow, small valves, small ports, etc.
Old May 15th, 2009, 02:29 PM   #19
1sl0w88's Avatar
88 LX 5.0 Convertable
1sl0w88 is on a distinguished road
Darrell,
Can the GT40P heads be used on the 351W ? Just drill out the bolt holes right?
Robbie
_________________
88 LX Convertible 5.0
84 GT - Project
66 F100
Old May 15th, 2009, 02:42 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by 1sl0w88 View Post
Darrell,
Yeah, they could but why? You might as well keep a 302 if you are going to do that. There is no point in taking a cylinder head that is less than adequate for a 302 and putting it on an engine that is 16% bigger unless making power is not one of your goals. A 351 will not breath very well thru that head. More cubes needs bigger heads, bigger intake, etc.
Threads Similar to: e7s vs. windsor heads
windsor heads? Boostang 96-98 45 April 3rd, 2009 10:51 PM
Romeo or Windsor heads ssprofession 96-98 2 February 1st, 2009 02:43 AM
Romeo or Windsor Heads jrfan4life 99-04 10 November 17th, 2007 06:16 PM
