will i have a problem? (head studs)
Old May 14th, 2009, 02:25 AM   #1
1993 SVT Cobra
93cobra670 is on a distinguished road
Send a message via AIM to 93cobra670
I'm changing over to head studs and have gotten the swap underway. I cleaned the threads in the block thoroughly (brushed them out, used brake cleaner, chased the threads, and dried them out). Then i installed the studs with arp moly lube on the top holes and with arp sealant on the bottom ones. I ran out of time and had to call it quits here. I didn't lube the top threads on the studs. Am i going to be in trouble in terms of the lube and sealant sitting overnight? Or will i be just fine to install the heads and torque them down tomorrow?
Black '93 Cobra
Supercharged 306
Old May 14th, 2009, 02:05 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Lube the studs before you torque.
Threads Similar to: will i have a problem? (head studs)
351W head studs MustangMatt96GT 5.0 Mustangs 8 May 11th, 2009 10:54 PM
Head studs and main studs? tommy023gt 2005 - 2010 14 March 5th, 2009 01:22 PM
apr head studs flattusmaximus78 5.0 Mustangs 4 August 10th, 2008 03:17 PM
need help picking head studs=( 93hatch 5.0 Mustangs 1 June 17th, 2008 01:29 PM
Head studs Vs Head bolts turbong 5.0 Mustangs 2 November 29th, 2006 04:28 PM
