Where to put the nitrous button....suggestions
Old May 14th, 2009, 11:26 AM   #1
stroked93's Avatar
1993 lx
stroked93 will become famous soon enough
i was thinking instead of the micro switch on the throttle body.....
i was thinking of wiring my right horn button with to the nitrous like this.....what do you think
idk why but i feel safer using it with the horn button and controlling it with my finger then on the TB
i mean i feel its a safe place because if i miss shift i dont want to go full throttle and then have the nitrous kick in and blow the f@#K out of my motor......i feel that the button will work better because i will have to let go of the button to shift and if i do happen to miss shift my hand will be on the shifter instead of the button.....catch my drift
and if theres a way to do it.....please explain
Old May 14th, 2009, 12:08 PM   #2
91 LX
13.7@101
pretty good idea. i haven't seen it...but none of my buddies run nitrous so
Old May 14th, 2009, 12:24 PM   #3
87 stang + 97 ranger
both combined i can't break 15 secs.
Cool Bam is infamous around these parts
Seems like it works.
Good idea to divide the two up.
I don't run nawz nor will I ever though.
[SIZE="3"][B][I][U][COLOR="Lime"]Loooking for a set of 16 x 8 Chrome Cobra R Style Wheels. [/COLOR][/U][/I][/B][/SIZE]
Something new in 2009.....You'll have to wait and see..... :o
Old May 14th, 2009, 12:32 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
Electrically separating the horn switches would probably require you to run new wires into the steering wheel and pass through the clock spring unless Ford does not tie them together until after the clock spring in the column. With schematics and a wiring diagram, you could figure it out, doable either way , but is the gain worth the effort? That is up to you. If you don't need a horn, it would be easier. In general, it does not seem like a safe idea to me, how many times have you passed by a wrecked car with the horn stuck on? What about a natural reaction to hit the horn, granted the bottle can be off but no horn will sound either.
Let us know the when someone cuts you off and you speed up to rear end them
Old May 14th, 2009, 12:50 PM   #5
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
How about a switch in the dead pedal on the floor, very easy to install and same as the horn idea with missed shifts. I prefure rpm activated switch or Throttle switch
Old May 14th, 2009, 12:57 PM   #6
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Yeah I would say ixnay on the horn button eh... Use a RPM activated window switch that way your only worrying about steering/shifting not steering/shifting/nitrous... And if you miss-shift you wont grenade anything because it is only activated between say... 3-5.5K rpm
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 14th, 2009, 01:58 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The problem with not having a wide open throttle switch is trigger happy rookies sometimes pull the trigger too soon before they are at wide open throttle. If you are going to use the horn, use it as an arm switch and the throttle switch as the activation switch so you will have to use both for the system to work. It will be safer that way. I have one question though. How are you going to spray and shift at the same time if you are holding your horn button in?
Old May 14th, 2009, 02:50 PM   #8
1993lxnotch's Avatar
1993 Mustang lx coupe
1993lxnotch is on a distinguished road
i know on a couple sportbikes i have done up with nitrous there is a kit that uses the horn as a double switch w/ a secondary two position switch. If that makes sense. Basically you have to flip a rocker switch located anywhere you choose....one position on the switch would be for the horn to work and the other postion would be for the nitrous to work. It turns your horn into a dual purpose switch depending on what position you have the other switch on. So when not usuing the nitrous you could still have your horn and when your ready for the nitrous hit the switch to make your horn button your go fast button
Old May 14th, 2009, 02:52 PM   #9
95StangMX's Avatar
95 Mustang GT
I think thats what he was saying he liked about it cause if he missed a shift he wouldnt be on the gas.....but then you are loosing out by coming off the gass when shifting
Threads Similar to: Where to put the nitrous button....suggestions
O/D Button? burnout5.0 94-95 8 May 22nd, 2012 09:26 PM
trunk button daschaffa17 2005 - 2010 29 October 12th, 2009 08:10 PM
Button Start? ModMustang97GT Modular Mustangs 7 February 2nd, 2009 04:48 PM
Brownie button? acehogg69 The Clubhouse 16 May 30th, 2008 05:53 PM
Nitrous plug suggestions Arrest Me Red 5.0 Mustangs 1 May 4th, 2007 08:04 PM
