trick flow R series and stock 5.0 motor
Old May 14th, 2009, 09:17 PM   #1
patwrecked is on a distinguished road
can i run a trickflow r intake on a stco 5.0 motor? are there any downfalls?
Old May 14th, 2009, 09:28 PM   #2
dblzroracin's Avatar
92 Mustang GT vert
dblzroracin is an unknown quantity at this point
Send a message via AIM to dblzroracin Send a message via Yahoo to dblzroracin
The TrickFlow R intake is total overkill on a stock motor, you will lose alot of low end power & torque. The TrickFlow StreetBurner will work best with a stock motor & a few nolt ons & the track heat will work well with some decent N/A mods like heads & cam.
www.bbandtracing.com
Old May 14th, 2009, 10:22 PM   #3
baine21225's Avatar
what are your plans for the engine? if its a basic bolt on setup then its overkill
Old May 15th, 2009, 01:43 AM   #4
I agree, you'll be slower then with your stock crap...
Old May 15th, 2009, 04:55 AM   #5
its not the box one. if i had trick flow heads and the matching lower on the stock shortblock would that be fine? i currently have longtubes, o/r x, 75mm proM mass air sensor. i got the upper for 150$ with the phenolic spacer.
Old May 15th, 2009, 07:16 AM   #6
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
well of course it would be different if you had heads, they are just replying to what you said before which is just the intake.
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD.
Plans: full black interior, black paint and supercharger???
Old May 15th, 2009, 07:53 AM   #7
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Yeah, absolutely would be fine with the TFS TW heads. Especially if you plan, in the near future, on a cam install. Thats a good price by the way, any pics?
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 15th, 2009, 08:39 AM   #8
92 Mustang GT vert
Adding just heads & cam would help alot, I still think the R may still be just a bit overkill even with just heads & cam without a power adder. The R is designed for the higher RPM ranges (2500rpm - 7250rpm), but hey you already have it so try it out & if it works well then keep it. Its definatly a nice intake. I have ran the R on my procharged 331 & it worked great then I switched to the box upper when it 1st came out while I was in the process of switching to a turbo & DFI setup & that worked out great too!!!
Old May 15th, 2009, 11:24 AM   #9
ill post a pic soon
Old May 15th, 2009, 11:33 AM   #10
91 LX
13.7@101
buy a cam and all supporting modifications and do it right the first time before you start slapping on parts.
Old May 15th, 2009, 12:54 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can run it on a stock engine but it isn't going to do much for you. Your heads are the bottle neck right now.
Threads Similar to: trick flow R series and stock 5.0 motor
Trick Flow ? sundro2000 5.0 Mustangs 4 June 6th, 2008 02:47 PM
trick flow Iownastang 5.0 Mustangs 7 July 6th, 2007 12:50 AM
gt 40 or trick flow? 95wip 94-95 8 April 21st, 2007 10:42 PM
Trick Flow 92mustanglx 5.0 Mustangs 0 September 3rd, 2006 05:13 PM
