What should I be gapping my plugs at?
Old January 24th, 2007, 09:19 PM   #1
sum_weirdo is on a distinguished road
My car is plagued with strange idle problems and I'm wondering if the gapping is playing a part. Stock gap for my 83 Tbird is .050. With modifications though my 302 is alot more similar to a Fox Mustang. It's got E7 heads, HO cam, Procomp HEI ignition, Weiand Stealth manifold, and a 570 cfm Holley Street Avenger carb. Any insight?
*Don't cry vacuum leak on me, there's only one vacuum hose coming off the engine and cutting it off doesn't change the idle*
Old January 24th, 2007, 10:08 PM   #2
have you messed around with your carb any?
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old January 24th, 2007, 10:19 PM   #3
Alot. That's what I get for buying it used. I consider it in good condition. I've been inside the fuel bowls, everything in there seems fine. I've messed with pretty much every setting in an effort to get it to idle properly. The best I've ever gotten it was with the floats way over spec and the idle mixture screws way up. Obviously that ain't right.....
Old January 24th, 2007, 10:53 PM   #4
Actually I guess it's possible the idle circuits are clogged.....I did run some Sea Foam through the gas a while ago but if the buildup is really bad maybe it wasn't enough. Any recomendations for cleaning them?
Threads Similar to: What should I be gapping my plugs at?
Spark Plug Gapping? SantanielloITA V6 Mustangs 20 November 10th, 2007 07:44 PM
NGK plugs GTsetGO General Tech 8 May 4th, 2007 10:26 PM
What plugs to use for my 87 GT? SDHW44 General Tech 0 April 19th, 2007 02:50 PM
Plugs 68 dlxcoupe 96-98 1 April 13th, 2007 03:12 PM
Gapping my plugs?? Bossman 2005 - 2010 1 January 29th, 2007 07:27 AM
