1989 Mustang GT 5.0
which cam would be great for a 1500 to 6500rpm range
im looking into trickflow heads/intake manny
im looking at the TF trackheat intake manny, and their TW aluminum heads so i was wondering what cam would be my best bet for a power range of 1,500 to 6,500rpms and going from all motor to turbo would the all motor cam have any negative effects on a boosted motor?
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
look at trickflows #2 cam if you want an off the shelf cam or have a custom one cut from cammotion
#3 | |
A turbo engine needs a different cam than a naturally aspirated engine.
use an f cam from ford, alot of people use it till they get to a 1,000 HP. its a really good turbo cam and you can get one for like 75 bucks
Ford Racing cams and good shouldn't be used in the same sentence.
1989 Mustang GT 5.0
hmmmm ive also heard mixed things about ford racing cams...they sound pretty generic to me,
the custom grind cams sound like the best bet!
Yes sir....There is no better
PeteAndersonRacing.com |
i know i know, i agree! but im just talkin from watching SEVERAL cars (even ones with stock heads) run goood numbers with a turbo and an f cam. im not saying its good for every application, but its a proven turbo cam.
12.9 @ 105
A mustang with a turbo runs good with a stock cam. It would probably run great with a custom. Chicken or Steak.
1986 LX
none yet
A cam for a N/A motor will be shit on a turbo set up if you know the difference. However if you have never tested different cams and different set ups you wouldn't know the difference between an e cam in a turbo car and a custom grind because you have nothing to compare it to. Now if youre experienced or at least knowledgeable about turboed cars, you will know that you will not get a good cam that will make you power from 1500 all the way to 6500. to get the most out of your turbo you will want something a bit more mid rpm ranged.
thousands for a turbo setup .. another hundred for a custom cam.
weeee foooord!
Can you show me some back to back track times or even dyno numbers? I would like to see some real life proof where the F cam makes more power or runs faster.
PeteAndersonRacing.com Last edited by 93mustank; May 17th, 2009 at 02:21 PM. |
It wasn't a comparison, he never said it made more power than another cam, he said he sees people making plenty of power with the F cam. That doesn't mean they wouldn't make more average power with a "better" cam.
trickflow stage 12
j/k lol
weeee foooord!
He does say its a "Proven Turbo Cam"
1990 LX hatch
If I scrape my cam on the ground a few times, is it considered a custom grind?
1989 Mustang GT 5.0
lol, thx for the help, this will give me a better idea when i do a top end kit,
i just want to match everything, and if i stick with the least amount of companies for parts i know it will work good together
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" Last edited by EscortSportage; May 18th, 2009 at 01:20 AM. |
Depends. If you only scraped 3/4 of it would it be a "custom grind 3/4 cam"?
Threads Similar to: which cam would be great for a 1500 to 6500rpm range
| goin to the range | Squints | The Clubhouse | 7 | January 10th, 2009 11:09 PM |
| The Great CAM Debate | weldreth | 2005 - 2010 | 42 | December 28th, 2008 11:11 AM |
| range | chickenbot | The Clubhouse | 2 | June 16th, 2008 05:17 AM |
| shifting past 6500rpm | DeMello | 99-04 | 13 | May 2nd, 2008 12:05 PM |
