Heads?
Ok so i was looking into getting new heads the gt-40 any of them they all give about the same hp increase from what im hearing. Anyways my question is this... When i change my heads with the gt40 heads will i still be able to pass smog with out any issues or changes.... or what will happen will it be better?
Also i have another question before i buy these what cc and all that should i get or does it realy matter? I have a basically stock motor just bolt ons. I will change my throttle body to a 70mm and my maf to a 70mm prob thats what im going to do... Ill also be changing my Upper and lower intake to the explorer one as well maybe the trickflow not sure which one i will be purchasing, yet. |
The Razor's Edge
the gt 40's came on the 93 cobra....considering they passed you should be fine
#3 | |
1990 Mustang gt
Darrel, how much needs to be shaved off the gt40p's to get 10 to 1. Is this with stock pistons. And what head gasket?
2002 gt 5-speed slow 1990 gt 5-speed junk |
I believe .030 but I don't remember for sure. A machine shop will be able to tell you.
#6 | |
1990 LX hatch
I used to have all the info, but I lost it. .030" mill was a hair under 10:1 with a .042, or .040 gasket. I cant remember.
ok i understang so if i get the gt40p heads i wont have to get them milled?
1990 LX hatch
If the surface is true, no.
i think it was the regular gt40s that would really need to be milled because of the larger combustion chamber
what about the gt40x heads
I'd have them resurfaced no matter what just to make sure you have a good sealing surface. That won't require much material be removed.
They have a 64cc chamber. You might want to cut them down a bit too.
Why not get some real heads? If you are going to pay for a GT40X head, why not get a Trick Flow, AFR, etc?
#13 | |
95 Mustang GT
![]() People should think about boarding up their glass house before starting a rock fight! |
Well how much better are the trick flow ones cause i was looking at them too.... i can get them of of ebay OH and i was looking at a trickflow intake toady whats the streetburner set? Is it good
Trick Flow heads are much better than any GT40 head.
What about the intake? i saw a upper and lower intake streetburner set for 100 bucks used but in perfect condition. from what i saw good deal better then the gt40 intake?
95 Mustang GT
yeah 100 bills is a great deal for upper and lower.......shit thats a steal....I would snatch it up b4 its gone...and its not old at all cause they just started calling them the street burner they were the street heat b4, unless they just are saying that in the ad to make it seem newer...but still a good deal
ok causei was like thats the street burner ones ok it looks new but it is used but still is it better then the cobra one like the actual cobra one cause i was looking at one that was brand new dude wants 170 for it it has the 70mm throttle body maf and rails and injectors too. to match
95 Mustang GT
That cobra one doesnt sound like a bad deal but what brand of TB and what injectors....I payed almost 400 bucks just for my 30 lb. injectors.....I am a little leary of buying used injectors but you can always take them and have them cleaned and checked but for 170 for the intakes TB's and maf isnt bad either depending on the brand and condition....
i'd grab the TF intake
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
Threads Similar to: Heads?
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 09:01 PM |
| 351W heads vs gt40p heads? | mustangsoldier | 5.0 Mustangs | 16 | December 10th, 2008 11:00 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 09:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 09:55 PM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 03:18 PM |
