Question about removing the lower intake
Old May 18th, 2009, 02:13 AM   #1
I Post Entirely Gay Too Much
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
I have read articles where they take off the lower intake with the black heater pipes and fuel injectors and rail still connected
But on mine there is a metal tab coming from the coolant pipes on the passenger side (ones that go to the heater core) that prevents me from removing the bolt without removing the black pipe. Last time I did it I broke the pipe and its like $120 if I remember right.
So how the hell does everyone else do it? lol
Do you need one of these?
Old May 18th, 2009, 02:36 AM   #2
Just twist the injector rails out of the way....
I usually bend the bracket to get a socket in there... Should be a stud with a nut.
PeteAndersonRacing.com
Old May 18th, 2009, 10:46 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Disconnect the lines and remove the intake. You can leave the rails and metal coolant pipe on the intake. Its easier to remove the pipe from the intake with the intake off.
Old May 18th, 2009, 11:28 AM   #4
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
If you end up breaking that black coolant pipe, I'm pretty sure I still have my stock one lying around...
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 18th, 2009, 05:42 PM   #5
dr.gonzo!'s Avatar
Yeah I just didn't get how all the tech articles I have been reading were getting to that stud bolt with that tab in the way
Old May 18th, 2009, 06:37 PM   #6
baine21225's Avatar
bend, remove
"Whip out your dick you'll either get it sucked or get smacked..."
Threads Similar to: Question about removing the lower intake
Lower Intake Question. 94StAnG5.0 94-95 7 March 17th, 2009 09:50 AM
lower intake gasket question.... 88stangGT 5.0 Mustangs 6 March 13th, 2009 02:46 PM
removing fuel lines on top of the intake manifold!?!?!? 94pacecarSVT 99-04 8 August 14th, 2008 07:58 AM
lower intake patwrecked 5.0 Mustangs 8 October 9th, 2007 09:50 PM
Need help using a 5.0 upper intake on a 5.8 lower intake Washington5.0 5.0 Mustangs 4 March 9th, 2007 02:54 AM
