#21 |
what truck?
#22 |
05 gt
slow!
the tow truck..
#23 |
the surge could be the TPS
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#24 |
05 gt
slow!
this is true hadnt thought about it but it was running fine no surge could it just have crapped out like that?
#25 |
the TPS is very fidgety, a setting on one TB might not be the same as another. One of by little screws came loose once and took me like 2 days of pulling what little hair I have out to realize that a screw was missing. The setting usually has to be very precise
#26 |
1990 LX hatch
Yes.
#27 |
05 gt
slow!
you sir just saved me a shitload of time and money
reps! |
#28 |
1988 Notchback
11.19 @ 122mph N/A
he said it was running fine after the install.
So I don't know if this is applicable, I mean anything is possible. I still think he should take ol boy for a one way trip
FluffyTheRhino: One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards. 1988 Notch 347 C4 w/brake 3.90 gear 11.19 @ 122mph 60' 1.67 N/A Full Interiored pump gas car |
#29 |
If it's backfiring and surging that has to do with vacuum.
What affects vacuum? Timing, vacuum lines, tps, weird idle afrs. So pull spout, set timing to factory spec Visual check on all vac lines (one came off on your new tb perhaps) Set tps with a vom (can't hurt ) and weird air fuel can be from a plug wire loose, cap loose, injector plug loose, high/low fuel pressure. Let me know
weeee foooord!
#30 |
Was that it? I'm just trying to throw ideas out there to help out . . .
#31 |
1990 LX hatch
check the TPS, voltage swing should be smooth thru its movement range.
#32 |
Maybe run him thru a chipper shreader. They will never find his remains. Make sure you run a bunch of wood thru it afterwords to clean out any obvious tissue and bones.
#33 | |
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
#34 | |
that's the liberal way to do it, but this is america "fuck yeah" Insert team america theme song lol But for real dude, dont mess with him, just look for the problem, take it to a shop, have them write up a receipt for 10x as much stuff as he fucked up
weeee foooord!
#35 | |
1988 GT
#36 |
that is a really good idea.
#37 | |
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
If it is infact the TPS just fix it and tell him you got it taken care of and you just had to buy a *Insert part here* for a couple hundred to do it. I personal check will be fine...
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis |
Threads Similar to: oh no batman!
| Batman Fans In Here | GTsetGO | The Clubhouse | 32 | September 9th, 2008 03:17 AM |
| Batman | itschristorres8 | The Clubhouse | 21 | July 28th, 2008 05:20 AM |
| wtf batman | nba1341 | The Clubhouse | 8 | March 28th, 2008 02:53 AM |
| 96 GT RAGTOP is BATMAN!!!! | G.T. Rags | The Clubhouse | 177 | September 9th, 2007 11:27 PM |
| If Batman Were Only Driving | DRIFTANG | The Clubhouse | 27 | September 21st, 2006 06:08 AM |
