LinkBack (1) | Thread Tools |
1993 5.ohhhh
12.97 @140mph
pulley swap on an s-trim
I recently purchased a smaller pulley to take advantage of low compression and being able to run more boost. How do I get the old pulley off. I do realize it looks as simple as unbolting the pulley, but I wanted to make sure there wasn't more to it.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1993 5.ohhhh
12.97 @140mph
48.47@ 12.58
to pull a pulley you need to purchase a pulley puller and proceed to personally pull the pulley.
1993 5.ohhhh
12.97 @140mph
So just unscrew that bolt then get a pulley puller. Then just put the new one on and tighten it up?
sawzaw
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
![]() use the right tool for the job....plasma cutter
1994 Ford Mustang GT
3 18mm bolts that hold the tension bracket/wheel (wrench) leave them loose
1 14mm bolt on the front of the pulley (impact wrench) slide off (dont lose the key) slide the new one on, put the belt back on and get everything tight again then go rip on it 15 minute job thats what my s trim was for my 94 gt
www.moddedmustangs.com |
1993 5.ohhhh
12.97 @140mph
thank you very much. Should be the same. Sounds just right without looking at the blower. Can that 14mm bolt come out with out an impact gun?
yeah its about your only hope, otherwise it will just turn whatever way you try to if using a regular wrench/socket, usually i have a buddy hold the pulley with some nice grippy gloves and put the impact on it and it spins right out
1993 5.ohhhh
12.97 @140mph
Gotcha... seems like the way to go. I'll give it a shot.
prbly need a smaller belt as well
1993 5.ohhhh
12.97 @140mph
That to. I had a 3.33 and am going to a 3.00. The blelt I have is retarded tight. I have the extra adjustable screw belt tensioner, and I had to take it off, have my huge friend hold the belt down with tension then swrew the tensioner to the bracket to hold it down. So I may give it a try.
If it's even a little loose it's GONE. Because of a big belt idk what my car made on 10psi.
1993 5.ohhhh
12.97 @140mph
That must of been one loose belt man.
1992 Lx
11.39@119.24
go to the goddam track!
#17 | |
1990 LX hatch
p, p, p, ppppPPPPPPPP!
1993 5.ohhhh
12.97 @140mph
Well from what this guy tells me, I don't need a puller.
i'd use a pulley puller, just sounds like a good idea
1993 5.ohhhh
12.97 @140mph
Hey lind. How did you fit an impact gun between theradiator and blower?
And hatch I will soon enough... Im just missing a aftermarket tach. I haven't been able to work in to weeks due to having an abscess. I just got medical attention so I'll be back on my feet in no time.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/123896-pulley-swap-s-trim.html
| MySpace.com - External Link Alert | This thread | Refback | May 21st, 2009 02:25 AM | |
Threads Similar to: pulley swap on an s-trim
| Vortech S-trim to T-trim is really worth it? | jivepepper | 99-04 | 41 | September 6th, 2009 04:50 PM |
| tune after a pulley swap | WilltheThrill | 4V / SVT | 3 | May 8th, 2008 08:28 AM |
| Pulley Swap | 2007 GT/CS | 2005 - 2010 | 7 | October 7th, 2007 12:54 PM |
| 8 rib pulley swap info | sonicblue | 99-04 | 12 | September 14th, 2007 10:57 AM |
