weird problem after tranny swap
Old May 19th, 2009, 10:50 AM   #1
r!ko88gtMEX's Avatar
1988 Ford Mustang GT
r!ko88gtMEX is on a distinguished road
here's my problem, i had the aod and decided to do go with a t5, after doing all the procedures, everything came out pretty good except for third gear being bad, but i don't care about that the problem is... i start my car once, starts up good, if i shut if off it won't start it'll crank all day but won't start, if i let it sit for a while about 20 min or more it'll start, that started happening after the tranny swap.. does it have something to do with that or not, and the other thing is that when it won't start, i pop the hood , disconnect 1 fuel injector and crank it, and the car starts right up, i plug it back in and drive off.
thanks !!
F!v3 pO!nT ... ooohhhh !! eL ZinKo-ZeRo..!!
Old May 19th, 2009, 11:59 AM   #2
95StangMX's Avatar
95 Mustang GT
I dont know for sure but someone was talking about this swap the other day and there is somthing about a switch that has to be bypassed for it to start correctly
Old May 19th, 2009, 12:31 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
This might be helpful for you. clutch/starter circuit short Need Help Please
Old May 20th, 2009, 12:29 AM   #4
so what can u guys tell me about the startiing problem??? haven't had any of those idle problems myself , it's just that it won't start for the second time till i unplug a injector
Old May 20th, 2009, 01:19 PM   #5
95StangMX's Avatar
95 Mustang GT
I am guessing its the computer....there is a neutral safety switch or something that needs to be programmed out or jumped or something....or just get the other ecu
Old May 20th, 2009, 01:43 PM   #6
91 LX
13.7@101
look at a manual trans car wiring diagram. neutral safety switch must be in place for it to start
Old May 21st, 2009, 02:02 AM   #7
car starts perfect the first time, the neutral safety switch es good, car won't start if i don't press the clutch in, so the switches are good , i'm thinking or i'm guessing my injectors are not shutting of or , they're spraying too much when the pump turns on because it seems to my like if it was a carburated car cause it looks like it floods out , or if i give the throttle pedal some kicks when it's cranking it'll start it's really pissing me off i haven't even drove my car the last few days cause it pisses me off to have to pop the hood in the middle of the street to unplug a injector so it'll start, the other day this fag with a z28 camaro pulled up next to me in the gas station and started talking shit, so i told let's quit the BS and go race... my car wouldn't start, dude said call me when you get that piece of sh... to start... pissed me off !!! of course i got my car to start , looked for the fag and smoked his hoopdy and got his chicks number ..!!! lol
Old May 21st, 2009, 08:36 AM   #8
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Maybe check fuel pressure? I've heard(don't quote me on this) that if the FPR goes bad then that will cause the injectors to leak/stay open.... Now i'm not sure if this is true or not just throwing it out there... I did an AOD to 5-spd swap myself but I bought the FRPP mass air convirsion at the same time, maybe that is why I had no issues? GL
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 21st, 2009, 08:47 AM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
Get it running, and use a stethoscope, or long screw driver. Touch it to the metal body of all the injectors, and put your ear to it. they should all tick, close to the same noise level, if you cant hear one that well, its not functioning properly.
Old May 21st, 2009, 10:21 AM   #10
i've got a mass air conversion also, haven't tried that injector thing, but i'll sure give it a try i'll keep you posted
Old May 21st, 2009, 02:45 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Scan for codes and post up what you find if anything. Did you change the oxygen sensor wiring harness when you did the swap? If not, you probably have a damaged computer that is causing the problem. Scan for codes first and we will go from there.
Another thing you can try is pulling the vacuum line off the fuel pressure regulator and check to see if there is any fuel in the vacuum line. If the diaphram in the regulator is ruptured it will allow fuel to be sucked out via the vacuum line into the engine after the engine is turned off causing a flooding issue. It still doesn't make sense that it is doing this after the tranny swap but it is something to check.
Old May 23rd, 2009, 08:23 AM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Any update on this r!ko88gtMEX?
Old May 23rd, 2009, 10:29 AM   #13
1988 GT
+1, whats the deal with this car... what was the problem?
That's how that happens... ooo.k. thanks for clearing that up.
Old May 24th, 2009, 04:41 PM   #14
car is still backfiring even after i played around with the timing and on that injector problem, still can't figure it out, haven't scanned it yet though , i'm picking up a 5speed computer today , just to see what it does , and the o2 sensor wiring , i'll swap that out and see what happens
Old May 24th, 2009, 04:48 PM   #15
something else i noticed on my car is that when i'm driving , i'll step on the gas and it'll speed up pretty quick and then sometimes it feels like if i got a turbo or something , cause when it reaches some rpms or something it feels like it goes faster or, it feels like when i had the little 75 shot on nitrous , all that comes after a loud series of poping out the exhaust lol
Old May 24th, 2009, 08:53 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Don't put that computer in until you can answer everything in my last post. If you have the wrong oxygen sensor harness in the car it will damage the computer and any new computer you put in. Check those things out that I mentioned.
Threads Similar to: weird problem after tranny swap
Weird tranny problems SilverFreakGT 99-04 9 April 1st, 2009 01:20 AM
Please help, weird tranny/ shifter question 97GT4.6 96-98 20 February 6th, 2009 10:12 PM
girls are weird / new tranny install. 97GT4.6 The Clubhouse 24 January 25th, 2009 03:56 PM
weird CEL after tranny installed? stang217 99-04 2 December 23rd, 2008 11:13 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
