1988 Mustang 5.0 LX
12.48@118.27
stuck bolts and bolts that will turn but wont come out
Hi I have a 1988 5.0 with 2 bolt that wont turn on my water pump on the one on the very left and right
1993 Mustang lx coupe
if you are asking how to free them you can either heat them with a torch and then try, or use a product called penetrating oil that you can get at any autoparts store or retail that has oil and stuff. I usually spray whatever i am going to be working on the night before with the stuff and then hit it again right before i start working on it. works great
get some PB blaster and spray em and tap the heads of the bolts with a hammer to loosen up the threads.if that doesnt work you gotta use some heat
Common problem. Typically it is bad enough that the head will shear off. Once sheared, I've seen someone weld a nut on the end and get it out. The heat and possibley the current from the welding helps break up the corrosion that is causing it to be stuck. Since your bolt head is still on, you can use PB blaster and let it soak in for a day or so and then maybe heat it with a torch? I don't know if that would help.
EDIT: From the time I loaded the page until I replied, others already said what I did Oh well.
little bit of the good lords strength
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Heat..
1988 lx
9.68@142
its turning but wont come out???
the bolts that wont turn tap the head with a hammer then heat them up then get a breaker bar on them..
if its turning but wont come out try prying underneath the head of the bolt with a flat head screw driver while turning the bolt...maybe it was cross threaded when you put it in and there are no threads left....once you get it out rethread it and chase it with a die for the thread pitch you have.
1988 Mustang 5.0 LX
12.48@118.27
its hard to turn and it only goes in a circle
1990 LX hatch
95 Mustang GT
I hate when a bolt only turns in a circle......WTF
![]() People should think about boarding up their glass house before starting a rock fight! |
so its stripped is what your saying?
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
has it unthreaded at all? sometimes gasket goop gets on the threads and wont let it release if this is the case hook on some vise grips and hit the grips with the hammer to pull out the pin. other wise hook on some grips and pull like all hell as you turn
1994 Ford Mustang GT
im lost lol, would love to help you but these guys have pretty much told you everything i know considering i dont know what your trying to say
www.moddedmustangs.com |
if its a bolt that goes through the timing cover, then it is possible the bolt has been bent. I've had it happen before and its a PITA. In that case, the vise grip and hammer method should work.
1988 Mustang 5.0 LX
12.48@118.27
thank you all for your suggestions but I got the bolt out the one that is going in a circle but I only have one more bolt left and that is the stuck one if I'm unbolting a bolt that is in the water pump can I warm up my engine to get the bolt off
1986 mustang gt
just keep working it back abd fourth, those bolts usually get all kinds of crap sticking to them so they wont slide out
1988 Mustang 5.0 LX
12.48@118.27
well I got heat and now half the bolt snapped off.
I have no freaking idea what you are saying dude.
weeee foooord!
Threads Similar to: stuck bolts and bolts that will turn but wont come out
| Help with header bolts - Locking header Bolts? | Rush | 94-95 | 4 | February 4th, 2009 05:37 PM |
| bolts | mpboy | 99-04 | 1 | March 30th, 2008 05:20 AM |
| bolts | mpboy | The Clubhouse | 4 | February 10th, 2008 06:50 PM |
| bolts | mpboy | 99-04 | 0 | February 8th, 2008 05:35 PM |
| motormount bolts stuck | sb2f5marine69 | 5.0 Mustangs | 8 | March 26th, 2007 06:10 PM |
