Top End Build Up 89lx 5.0
Old January 25th, 2007, 01:54 PM   #1
89BEAR is on a distinguished road
Thinking about the following for my motor build up:
Adding Elelbrock 170 CNC PORTED HEADS
X CAM
75MM TB from present 65mm
1.6 roller rocker
24lb injectors
255 in tank fuel pump
This was suggested to me and was told there are no issues
with the Elelbrock heads and that the Trick Flows were a little better
but very tricky to install.
Can I run the x cam with this setup being a stock 302 or must they
be fly cut?
I am presently running gt 40 upper and lower intake
3.55's
Headman Headers
E303 CAM
HIPIPE
MSD IGNITION 7 TAYLOR WIRES
PULLIES
65MM TB
CLUTCH
Old January 25th, 2007, 07:20 PM   #2
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
im thinkin you'll nedd you pistons cut for that extra clearance..but im not sure.
personally, i wouldn't go with an x303...There are better cams out there for the same price..
Old January 25th, 2007, 07:27 PM   #3
Any suggestions of another cam and have you heard
good things about the Elelbrock heads?
Cheers!
Threads Similar to: Top End Build Up 89lx 5.0
302 Build 83five0 5.0 Mustangs 4 September 30th, 2007 02:17 PM
New Car Build exploderpilot 5.0 Mustangs 14 August 15th, 2007 01:53 PM
306 build up 92mustanglx 5.0 Mustangs 12 June 7th, 2007 11:46 AM
just about to build fastpony V6 Mustangs 11 December 30th, 2006 01:59 AM
