mass air meter question.
So im about to finish up my gt40 intake and heads on my 93 5.0. Im a little tight on cash and not able to afford a bigger air meter. That meter is the last thing chokeing up my engine. It sucks to notice how much bigger the ports are on the gt40p heads and how much bigger the manifold is opened up compared to stock, and when i look at the stock meter it is such a small opening. Question is can i pull out my stock sensor in the meter and stick it in my 3in steel intake tube for now until i can afford a 80mm meter? Im not changing the injector size until i get the 80mm by the way. what do u guys think? Im pretty good at fabbing stuff up so is it possible to make something work with my stock sensor in a larger tube for now?
1990 LX hatch
No!!!! That would be a bad idea.
i personally have never heard of that so i wouldnt recommend doing it. if your not in a rush save your pennies and get one down the road
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD. Plans: full black interior, black paint and supercharger??? |
1990 LX hatch
The sensor wire has to have a precisely metered amount of air to flow over it.
oh well, it was worth asking i guess. Ive seen some 76mm housings with no sensors on ebay real cheap, can I buy one of those housings and pick up a sensor to drop in it? Where can I buy just the sensor if I go this route? Looking for one set up for #24 injectors? Or would i be better off spending 300 bucks on one that will just plug in? Id like to go the cheaper route. they arent cheap.
The Razor's Edge
just wait and do it right the first time.....
Wow.
#8 | |
1990 LX hatch
It depends on what kind of sensor, and meter. A C&L uses your stock sensor, and alters the air flow over it. Others use a bigger housing with an altered sensor.
Threads Similar to: mass air meter question.
| mass air meter question | gotn20 | 5.0 Mustangs | 3 | May 11th, 2009 11:35 PM |
| Mass air meter | cobrarob | 4V / SVT | 1 | April 9th, 2008 10:26 PM |
| Mass Air Meter | Euroeater95 | 94-95 | 7 | November 16th, 2007 04:00 PM |
| MAF mass air meter | neckbonekat | 99-04 | 6 | February 22nd, 2007 09:58 AM |
| Mass Air Meter Question (Cobra 70mm) Help | cobraetti | 5.0 Mustangs | 0 | October 30th, 2006 05:52 PM |
