broken valve cover bolts
Old May 23rd, 2009, 12:50 AM   #1
1986 LX
none yet
jtyson8602 is on a distinguished road
Got the motor out of my old car and Im gonna freshen up the gaskets and what not while its out, but I have a broken bolt on each valve cover. Tried tapping one out and busted the tap in it. Any suggestions on how to get it out now? nothing is sticking up above the surface so I cant grab with anything. Should I just cut out the threads and all and step up a bolt size or will I be hitting any water jackets or anything? They are just stock e7s. Yes I know I should just get new heads but thats not in the budget now.
Old May 23rd, 2009, 12:53 AM   #2
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
Good luck if you broke an easy out in there. They are hardened steel so you will need a cobalt bit. Some oil & alot of paitents.
www.1fun4rd.blogspot.com
Old May 23rd, 2009, 03:09 AM   #3
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
Take it to a good machine shop, auto or a tool and die shop, and they can burn the tap out for you..
Old May 23rd, 2009, 08:33 AM   #4
1986 LX
none yet
do you know how they do it? I have quite a few of the tools that machine shops have, but I have never messed with anything like this as I have never broke the bolts before I have always been real careful. Is it as simple as gouging it with my plasma cutter or something like that?
Old May 23rd, 2009, 10:56 AM   #5
1989 LX coupe 5.0L
89lx is on a distinguished road
easy fix buy a new set of heads
Old May 23rd, 2009, 10:57 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You were trying to get the broken bolt out with a tap?????
Old May 24th, 2009, 05:49 AM   #7
1990 LX Coupe
It's a machine that burns the broken tap, or in your case a bolt out of the hole. It has a rod on the end that looks like a welding rod and it basically just burns the tap out..
Old May 24th, 2009, 11:01 AM   #8
1986 LX
none yet
forgive me, easy out. just a typo
Old May 24th, 2009, 12:19 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Oh. You had me worried for a minute.
Old May 26th, 2009, 04:17 PM   #10
PJC Racing is on a distinguished road
You could try welding a nut to it and then back it out, depending on how deep it is in the hole. This is how I remove almost all broken bolts.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
Old May 27th, 2009, 01:07 AM   #11
1986 LX
none yet
its set about 1/16th of an inch down into the head. I can tig something on but nothing that wont just bend or break right away. not much room for a good weld there
Old May 27th, 2009, 07:22 PM   #12
A 1/16" isn't much. The key is to use a larger bolt than the application, 3/8" or 10mm, to allow you a little room to get a good bead. You can prep the surronding area with torch head grease (I forget what the real name is) to help prevent the bead from sticking to the head. Just a thought.
Threads Similar to: broken valve cover bolts
timing cover bolts?? Boostang 99-04 6 April 6th, 2009 05:16 PM
Lost Timing Chain Cover Bolts Help rusty2407 5.0 Mustangs 2 June 28th, 2008 09:55 AM
broken valve??? shortskirtsnturbos Modular Mustangs 2 April 29th, 2008 05:04 PM
Broken Valve cover bolt kinghack 2005 - 2010 6 February 21st, 2007 05:45 PM
Broken Bleeder valve cobralini 5.0 Mustangs 4 May 13th, 2006 03:33 PM
