Front motor plate...
Old May 23rd, 2009, 12:14 PM   #1
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Competition Engineering Front Motor Plates: CEE-4001 - summitracing.com
I was wondering if this is something that I can use on a street driven car? It's not my DD. Also is this part something thats worth all the work for install? Has anyone installed one before and know what I should expect. Is this a DIY or something I need to bring to a shop and have done? Let's bring up some pros/cons if anyone has any... Thanks
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 23rd, 2009, 08:31 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Seems like alot of work. I'd just do solid motor mounts.
Old May 23rd, 2009, 10:09 PM   #3
1998 Cobra
13.24@105.66
why?
weeee foooord!
Old May 23rd, 2009, 10:30 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've used motor plates on the street. They take stress off the cylinders that solid motor mounts cause. For this reason I feel they will also help the stock block live longer. They require some fabrication though. A motor plate is not a bolt in deal. It will have no effect on daily driveability.
Old May 24th, 2009, 11:20 AM   #5
1988 GT
thanks darrell... If I have the front motor plate do I "have" to run the rear plate? I'm assuming by fab. you mean welding? or just cut/fitment issues?
Old May 24th, 2009, 12:19 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No you won't need a mid plate but you will need engine mounts still unless you plan on some other lateral mount to keep the engine secured front to rear in the car.
You will need to cut the plate to fit, weld mounting tabs, swear, throw wrenches, etc.
Old May 24th, 2009, 06:16 PM   #7
1988 GT
Sounds like a job for... Broken Knuckles Garage! lmao, maybe I'll wait to do this... when I swap trans'.
Threads Similar to: Front motor plate...
Retractable front plate! Rico-mofos 2005 - 2010 18 February 13th, 2009 02:57 PM
Front licence plate ZincStang Visual 11 November 13th, 2008 12:43 PM
Front License Plate cmdr_anomic 2005 - 2010 28 April 11th, 2008 09:31 AM
Front plate mumbles483 2005 - 2010 4 September 30th, 2007 02:03 PM
Front license plate Amanda 99-04 10 April 25th, 2007 10:40 AM
