FFR Cobra and 05' GT vert
Whats the highest compression ratio??
Whats the highest compression ratio that can be run on pump gas?
My car weighs about 2100 pounds, has a 4.10, will have aluminum heads.
Go big or go home! |
11:1? i think? correct me if i'm wrong
93 octane with aluminum heads and the right cam can probably do 11.5:1 - 12:1. 11:1 will be safe.
Ok. Well, it figured my compression will actually be 10.69:1 with 58cc heads. I've decided on the canfield 195's for my head choice. I think they will work nicely.
If I go with the 54cc heads, this will bump the compression to around 11.2:1. This should be ok on 93 octance with a Jay allen camshaft?
yes it will be ok. nice choice on heads..i am going to run them too. it sounds like you are making good choices on your engine build..good luck and keep us posted
#6 | |
The Razor's Edge
post more about this motor and car.....2100 lbs....
Cobra kit car.
yeah my uncle has a cobra kit car with a built 460 in it.....it is absolutely disgusting. also has spray hooked up on it but he has never used it
Threads Similar to: Whats the highest compression ratio??
| Compression Ratio | wannabeimportkiller | V6 Mustangs | 4 | March 31st, 2009 02:12 PM |
| compression ratio | moosenuk17 | 99-04 | 11 | March 4th, 2009 09:26 PM |
| highest compression for 93? | tehdwarvenn | 5.0 Mustangs | 17 | February 4th, 2008 09:31 PM |
| Compression Ratio | invisa stang | 5.0 Mustangs | 8 | January 8th, 2008 06:28 PM |
| compression ratio | mustangrebuilder | Classic Mustangs | 13 | August 14th, 2007 10:08 PM |
