blinker not working help
i already check the fuse and i bought a new wiper switch not just for the blinker but for the lights. i cant seem to find out whats wrong. any help
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
1988 lx
13.13@101.78
i've got this same problem but what happened was i took my dash out to swap from an 85mph speedo to a 140mph speedo and when i pulled it out the wires on the back of the hazard switch plug came undone. So i bought a new switch and wired it up and everything worked(incorrectly but worked none the less) but now its grounding out somewhere. Long story short, check your wiring.
![]() 302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's |
12.9 @ 105
There is a round silver relay in the fuse box for the blinker. You probably need a new one. If you took anything apart then i would check what you took apart.
1990 LX Coupe
Check the blinker fluid, it might be low.....
Sorry but I had to.. lol |
Check the wiring on the hazard switch.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress) 86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
#6 | |
95 Mustang GT
![]() People should think about boarding up their glass house before starting a rock fight! |
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
dumb suggestion but have you checked the bulbs? Silly i know.
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
1990 LX Coupe
1994 Ford Mustang GT
just pick a bottle of this up at any of your local hardware stores
www.moddedmustangs.com |
ok well i looked at the back of the fuse box to make sure all the wires are still conected and even bought a new relay. the waring lights dont seem to work either mayb they have a connection
Threads Similar to: blinker not working help
| Blinker problem | icon | Audio/Video | 6 | October 29th, 2008 09:21 PM |
| blinker and lights help | emgjsdk1 | Audio/Video | 0 | March 6th, 2008 03:57 PM |
| Issue With Blinker | G.T. Rags | 96-98 | 12 | December 30th, 2007 01:39 PM |
| Blinker | orbface9 | V6 Mustangs | 12 | December 13th, 2007 10:54 AM |
| blinker and horn | 93fourbangerstanger | 5.0 Mustangs | 3 | September 20th, 2007 12:22 PM |
