Will this mass air work on my 93 5.0?
Old May 29th, 2009, 12:57 AM   #1
5.0 street stanger is on a distinguished road
I asked for a part number so im waiting on that from the seller. I thought that ford meters arent calibrated for injectors? I had thought that it was the computer not the meter when it comes to fords. Am I wrong? Im going to get a cheap used 80mm for now until I can get one from ford anderson. Not sure about this meter working on my 93 5.0 auto. Ebay item number 360157902507
87-04 FORD MUSTANG COBRA 80mm MASS AIR METER MAF SENSOR:eBay Motors (item 360157902507 end time May-31-09 19:08:13 PDT)
Old May 29th, 2009, 12:59 AM   #2
Buy it now is $65. Is it worth that much? or would I be over spending?
Old May 29th, 2009, 10:41 PM   #3
Somebody who knows? come on now. the auction ends soon.
Old May 29th, 2009, 10:59 PM   #4
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
It's the computer in the car that will need the help. It won't know what the hell hit it if you throw that on it.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old May 30th, 2009, 09:47 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why don't you just buy a good mass air meter rather than trying to piece together second hand junk? You can make it work, no question there but I'm a fan of doing things correctly the first time.
Old May 30th, 2009, 11:22 PM   #6
im tight on cash right now but dont want to give up working on the car. Im starting a business and im putting all my money into that. So until I can start getting money back from the business, I have little to put into the car money wise. But will It work as a plug and go or will the computer need to be changed?
Old May 31st, 2009, 05:51 AM   #7
JBIGBOOTSY's Avatar
1990 LX hatch
It all depends on if the voltage/flow values given by the meter match the voltage tables in your computer. Verry close is ok. but Its hard to tell. If that meter came out of a stock ford vehicle, then you have about a 20:1 chance it will work fine.
Old May 31st, 2009, 09:49 AM   #8
e3sean's Avatar
1988 lx
9.68@142
it will cost you 475 for the chip and tune on your computer to get it to work. plus the plug adaptor on to the maf.
i have a 76mm c&l ill sell ya for 100.00 its set up for 30# imjectors but with a new flow tube that run about 20 bucks you can set it up for any size injector you need.
<font size=4><b>MILITARY CREW
Old May 31st, 2009, 03:59 PM   #9
Ya ill PM you after I think about it some. What exactly is different about the C&l verses a regular mass air? Is all the tuning done in the sample tube? I dont get how it works exactly. Can i switch tubes to different sizes and it will work fine or would i need a chip or something? Elaborate please.
Old May 31st, 2009, 04:32 PM   #10
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
the tube just changes the meter inside the housing of the maf....all you do is change the tube and change injectors.....but its the same as any other meter in that if you go larger than 30 pounders your gonna have to do some tuning
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old May 31st, 2009, 09:44 PM   #11
so will those sampling tubes work in any meter then, or just c&l meters? If i were to get the one that im looking at on ebay could I just change tubes for future upgrades with injectors?
Old May 31st, 2009, 10:30 PM   #12
1990 Mustang GT
no the c&l housing is made to accept the tubes....its the only meter i know of that you can just swap them in and out like that
1990 GT
2004 Impala SS
2001 Tacoma
Threads Similar to: Will this mass air work on my 93 5.0?
Will this Mass Air meter work on my 93 5.0? 5.0 street stanger 5.0 Mustangs 4 May 25th, 2009 11:12 AM
Air intake/Mass Air flow John's_stang 99-04 9 March 9th, 2009 11:53 PM
mass air terribleonexx88 5.0 Mustangs 2 July 30th, 2007 02:52 PM
Anyone have problems with MAss emissions after motor work? jrfan4life 99-04 11 July 25th, 2007 01:46 PM
Cold-air/Mass air, What's the difference? clinton_stearns V6 Mustangs 1 August 19th, 2006 10:20 PM
