Need quick help about a breake related part
I need to replace a part that it's leaking but I dont know what it's called. it is a metal part that has 2 brake lines coming in from the master cylinder reservoir and 2 lines going to the brakes. It is located right bellow the reservoir. I called Autozone and Advance and they don't know unless I give then the name. i think it is a brake pressure proportioning valve or something. can anyone help me with the name? it is leaking now.
thanks. |
Proportioning valve. Good luck finding one at an auto parts store.
1988 GT
Can't you do a rebuild on this part... GL on the hunt for a new one
1994 Ford Mustang GT
you can get a master cylinder at any auto parts store, comes with the portion value and the reservior 2 bolts on the firewall and bleed the lines, problem solved
www.moddedmustangs.com |
I've never seen a master cylinder come with a proportioning valve. You are not talking about a proportioning valve, you are talking about the master cylinder.
That is correct. Autoparts dont carry it. it is the proportion valve. the problem with the leak is the rubber piece that goes on the threaded bolt in front of the valve. I did a quick fixed and so far zero leakes. I bolted a small stainless steel bolt and since the nut is made out of alluminum, the bolt went in and made a nice thread. Does anyone knows why it has the ruber piece instead of a cap without the hole? Does that rubber piece serve any purpose?
Threads Similar to: Need quick help about a breake related part
| Quick and simple non car related chop. Help! | keeprollin02 | Chopshop | 9 | March 12th, 2009 01:39 PM |
| AM BLOG CONTEST - Name That Part Win That Part!!! | AMNick | American Muscle | 0 | January 28th, 2009 12:03 PM |
| Import related | Luis_GT | The Clubhouse | 20 | July 2nd, 2008 12:17 PM |
| NOT perforance But related to 2.3L | -cold-machine- | 2.3 Mustangs | 7 | September 26th, 2007 03:30 PM |
| Tech related ... but | Onemanzu | The Clubhouse | 9 | September 25th, 2007 02:51 AM |
