Proud American
Flaming River Steering Issue
Well since I could not get my steering to work, I ordered up a Flaming River Manual Rack and Pinion for 94-04 cars. Turns out that I now need different outer tie rod ends (different thread than the stock ones). I also am going to have to buy one of there steering shafts or get an adapter.
Has anybody ever had the thread issue with fox body cars? Maybe my SN95 is just different than the Fox cars. Also anybody used the adapter rather than the whole steering shaft? Thanks Matt
The Razor's Edge
can you rethread or is it bigger?
Proud American
not going to beable to rethread it... I wish it were that easy...
what a money pit this thing has become...
The Razor's Edge
its a bad ass money pit...im a fan....
Proud American
I am just sick and tired of it.... cannot wait for the first time i can pull it into the trailer knowing that the track is only 7 miles down the road...
The Razor's Edge
you need to get down to sea level dammit...i rememeber the first time i seen your times...i was like WTF that aint fast lol
Proud American
11.80s on motor would make me happy at this altitude... thats plenty fast for an 18 year old.
Proud American
Called Flaming River... and I have to buy a special shaft, because I used a SN95 car.
They also just told me to use a Tap on the inside of the outer tie rod to fix the issue of being the wrong thread. Hope this is correct. But i ordered the shaft now too!
Proud American
Look!!! The car turns left again!
![]() now i just got to wait for my steering shaft from summit to come. And also got some offset rack bushings. Then I can put the car back on the ground, and possibly take it to the alignment shop as is, or put the engine in it, and then take it to the alignment shop after the car runs...
You should have bought the kit, not just the rack. The kit comes with outer tie rod ends and the steering shaft.
Why do you want offset rack bushings? Do you need more oil pan clearance?
Proud American
Bump steer issues is the reason I got the bushings. And I would have ordered a kit, if the had one for SN95 cars. But all the kits were for foxes and had a shorter wide rack and a different shaft. The SN95 shaft is a replacement from the colum back under the dash, where the kit that my friend got for his fox, was only half that to the rag joint.
I rethreaded the tie rods and set it up as stright as I can get it. And I can reuse my old bushings if it turns out I done need the off sets. Although not sure I shouldeven be worried about bump steer with the car being a drag only car, unless when I come back down on the front tires, that it will cause the car to turn its self.
#12 | |
Here is the kit. Flaming River FR1892 - Flaming River Manual Rack and Pinion Steering Systems or this one Flaming River FR1892D - Flaming River Manual Rack and Pinion Steering Systems or this one Flaming River FR1892Q - Flaming River Manual Rack and Pinion Steering Systems
Proud American
None of those had the 1509M steering shaft I needed. I also needed a 1508 rack. I wish I were building a fox, it would have been much cheaper.
Those aren't fox body kits, those are kits for your car. 94-04. They all have the manual rack and shaft for your car. The part number is the kit part number, not the rack part number. I've used them in a couple of cars now.
Proud American
Oh, well my mistake. When I called flaming river, they said that they didn't have a kit that would work for me. Must have gotten the obama supporter worker there that isnot willing to help and is there just to cause problems.
1986 mustang gt
u gotta have the car sitting the way it would normally sit, with u and all the drivetrain in it, in order to get the alignment dead on
what does that even mean??
weeee foooord!
Threads Similar to: Flaming River Steering Issue
| Steering Issue in my 351 build | MustangMatt96GT | 5.0 Mustangs | 12 | April 26th, 2009 10:22 PM |
| Power Steering Issue | TomRob77 | Classic Mustangs | 3 | April 13th, 2009 06:39 PM |
| Flaming River Qiuck Or Standard | flamestang | 5.0 Mustangs | 10 | November 27th, 2007 03:45 PM |
| Lets gather at the river :) | TurboLX | The Clubhouse | 27 | June 22nd, 2007 08:40 PM |
