water pump bolts
Old May 31st, 2009, 10:17 PM   #1
vinsanity2701's Avatar
1988 Mustang GT 5.0
N/A
vinsanity2701 is on a distinguished road
water pump bolts
Got an 88 GT and the water pump took a dump on me. Got everything off down to the pump itself and then looked closley at the 4 studs protruding from the block and apparently the idiot who owned the car before me decided it would be a good idea to put what looks like JB Weld on the threads to keep the nuts from coming off. Tried heating them but ended up snapping a bolt. Im assuming that all of the bolts are jb welded because none of them will move. Any suggestions on how to get these out besides tap and dye or pulling the block?
Black Beauty
MILITARY CREW E-4/AD3
"I know a few people like that. The ones that have the best sh*t money can buy, but dont know how to change the oil or check the air pressure...LMAO"
Old May 31st, 2009, 10:29 PM   #2
The Razor's Edge
White Thunder's Avatar
why are you not considering tap and dye?
think you could drill them out?
founder of the FTN Club
Old June 1st, 2009, 05:17 PM   #3
PJC Racing is on a distinguished road
Heat with a torch.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
Old June 1st, 2009, 09:23 PM   #4
The Razor's Edge
he did....
Old June 1st, 2009, 09:29 PM   #5
83 5.0's Avatar
83 5.0 is on a distinguished road
If you have access to a Mig or Wire feed welder, take a nut and put it over the stump of the stud, and weld the nut (through the center) to the stump.
Heat will usually help break it and you should be able to twist it off.
These are a B***, and almost always one stud breaks off.
Good Luck check out this demo Removing a Broken Stud for MIG Welding | Expert Village Videos
Old June 1st, 2009, 09:54 PM   #6
The Razor's Edge
expert village is the shit
Threads Similar to: water pump bolts
Water pump bolts Burn'nRubber 5.0 Mustangs 3 March 24th, 2009 04:16 PM
Suggestions for an electric water pump or water pump motor. N. Dave 5.0 Mustangs 4 October 5th, 2008 08:49 PM
Water pump ?'s DickH 99-04 13 August 16th, 2008 06:52 AM
water pump 99blkcobra 4V / SVT 23 May 27th, 2008 05:10 PM
Water pump 90Stang 5.0 Mustangs 13 July 8th, 2007 04:57 PM
