#21 |
Trick Flow Specialties TFS-51400004 - Trick Flow® Twisted Wedge® Street Cylinder Heads for Small Block Ford
picked these up ready to go with 1.6 rr for 875 shipped have 2000 miles on them but they look to be in good shape first real mod on my mustang so im pretty stooked what spark plug should i get for the install also go with fel pro gaskets correct ? next will be the 255 fuel pump , rails and 24# injectors then intake
if you were on a bicycle and we were going up hill i could beat you in a race |
#22 |
Fel pro's will be fine
Autolite 25's work great. Gap them at factory spec. I would do intake before injectors. 19# should be able to support those heads
weeee foooord!
#23 |
1988 Notchback
11.19 @ 122mph N/A
19# will be fine on those heads
FluffyTheRhino: One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards. 1988 Notch 347 C4 w/brake 3.90 gear 11.19 @ 122mph 60' 1.67 N/A Full Interiored pump gas car |
#24 |
No, these heads use Autolite 3924 plugs. And the factory gap spec is pretty wide, I would gap at .035-.045".
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress) 86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
#25 |
thanks for the info on the spark plugs, ill gap them at .035-.045" and see how that runs
also good to know the 19#ers will be fine for awhile then i will def do the intake first i called a lot of shops here in reno nv and the cheapest quote i got was 1000 some were 1300 and a few were even 1500 obviously i got lower quotes from people on craigslist but i dont think people on craigslist will give me any type of warranty and not sure if im getting some shaddy work done i guess you get what you pay for the shop that quoted me 1000 said that it included a full tune up after install and a dyno pull
#26 |
lol well shit... I've been running autolite 25's in my sbf heads forever now.. may need to change.
weeee foooord!
#27 |
25 style would be for E7's. Almost all after market SBF cylinders heads run 3924 style shoulder/gasket plugs (as with the Trick Flows). The threads are the same but the depth is much differnt. GT40 use 764 style plugs again same thread different depth and sealing area.
#28 |
good looking out pjc
#29 |
1981 4 EYED FREAK
9.48@147
X2, we do em all the time and thats way overkill, I have done it for 450$ for repeat customers..(headswaps)
![]() www.rodeheavershotrod.com 9.48@147 on pump gas through the mufflers, still has pw,tilt,t-tops,all lights, wipers!!! , check out the vidhttp://www.youtube.com/watch?v=SloE3Zdetac |
#30 | |
+1
#31 | |
#32 |
when i change the injectors up to 24#ers will i need to change the maf and get a tune?
i assume it would be best to change th emaf at the same time as the injectors? what size maf / throttle body should i run with this setup and the 24#ers
#33 |
Yes. Get the biggest mass air meter you can find. You can get a tune to correct the injector size or you can fool the computer with MAF electronics. The better way is with a tune.
Threads Similar to: heads and gaskets on a budget
| H/C/I combo with 5K budget | bcinthearmy | 94-95 | 22 | January 13th, 2009 01:44 PM |
| 5.8 budget build help | riggsracin | 5.0 Mustangs | 5 | November 21st, 2008 08:57 PM |
| budget horsepower?? | stangempire82 | 99-04 | 110 | October 27th, 2008 12:31 AM |
| Budget heads. | INSTALLER020 | 5.0 Mustangs | 12 | August 12th, 2008 03:23 PM |
