#21 |
Proud American
A knocking sound
#22 |
1985 Mustang GT
oh, lol
#23 |
1988 Notchback
11.19 @ 122mph N/A
I run 20W50 in my turd all year long, but I live in South Louisiana. I heard the video also. Kinda sounds like bearing failure to me, which would also explain the variance in oil pressure. It's either bearing(s) trying to stack up in one of the journals or a lifter bleeding off for some reason or other. Either way, when you and your people pull the engine and pull the pan. You might as well start pulling main caps off and inspecting bearings, move on rod end caps if everything looks good on the mains. Like I said, I suspect bearing failure to be the culprit first, second being lifters collapsing which could be due to low oil pressure from bearing failure also. It is a big mystery and guessing game untill you get the engine out and do inspections. LUK
FluffyTheRhino: One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards. 1988 Notch 347 C4 w/brake 3.90 gear 11.19 @ 122mph 60' 1.67 N/A Full Interiored pump gas car |
#24 |
1988 Notchback
11.19 @ 122mph N/A
A long screw driver will also work, especially the ones with metal all the way through the handle. I have several like this and use them for such.
Threads Similar to: Car is hard to start and other issues after oil change...
| How Hard is it to change both axles?? | silver2006foose | 2005 - 2010 | 8 | February 18th, 2009 11:39 AM |
| oil change turns into oil disaster | GTblackprodigy | The Clubhouse | 23 | July 16th, 2008 05:35 PM |
| hard start tune up ? | jrock | 99-04 | 9 | March 15th, 2008 09:07 PM |
| Hard To Start... | Tdog10015 | V6 Mustangs | 9 | October 27th, 2007 02:33 AM |
| hard to start | 88stang | 5.0 Mustangs | 10 | April 16th, 2006 06:08 PM |
