gt40 heads
Old June 1st, 2009, 06:34 PM   #1
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
gt40 heads
How much does a decent pair with oh say 120k miles on them no work just pulled straight off the block go for whats a good price
Old June 1st, 2009, 06:44 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
0-200max
Old June 1st, 2009, 07:01 PM   #3
PJC Racing is on a distinguished road
I'm with JBIGBOOTSY, $200.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
Old June 1st, 2009, 07:10 PM   #4
1989Gt.'s Avatar
1989 Mustang GT
K thank you fellas what about the upper and lowerintake no work?
Old June 1st, 2009, 07:15 PM   #5
Not sure of your question? Are you asking what a GT-40 intake would be worth?......Tubular $300-500, Explorer $100-250, Cobra $200-400
Old June 1st, 2009, 09:24 PM   #6
The Razor's Edge
White Thunder's Avatar
get the heads done up before you put em on
founder of the FTN Club
Old June 2nd, 2009, 12:08 AM   #7
1998 Cobra
13.24@105.66
+1 on re-furbishing the heads.
At a minimum put new guides and good springs in it.
weeee foooord!
Old June 2nd, 2009, 11:17 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by JBIGBOOTSY View Post
0-200max
I'm with these guys.
Old June 2nd, 2009, 12:14 PM   #9
1998 Cobra
13.24@105.66
If your pulling heads of a junkyard car, no telling WHY it's in the junkyard.
I would swing them by the local machine shop to check them out
or just be a hard ass and slap them on and raise hell.
weeee foooord!
Old June 2nd, 2009, 04:45 PM   #10
stfudvs's Avatar
302 5.0
stfudvs is on a distinguished road
which gt40 heads are the ones that will match up with a stock exhaust and are a direct bolt on
if you were on a bicycle and we were going up hill i could beat you in a race
Old June 2nd, 2009, 06:13 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
At minimum they will need to be resurfaced, new valve seals, new valve springs and a valve job.
Old June 2nd, 2009, 06:16 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Non P heads. The Explorer GT40 heads have 65cc chambers which is about 4ccs more than the other stock 5 liter heads. Just something to keep in mind. They can be milled to get the compression back up though.
Old June 2nd, 2009, 06:39 PM   #13
stfudvs's Avatar
302 5.0
so the gt40 cobra cylinder heads dont really net much gains unless milled ?
Old June 2nd, 2009, 06:52 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The Explorer GT40 heads need to be milled to keep the compression at 9:1. The Cobra GT40 heads have the same size chambers as the E7 heads so there is no issue there. There is about a 20hp gain with GT40 heads.
Old June 2nd, 2009, 06:59 PM   #15
1992 Lx
11.39@119.24
1 bag o dicks
Old June 2nd, 2009, 07:42 PM   #16
stfudvs's Avatar
302 5.0
i think i will hold off on the cam/intake and just try to get some twisted wedge heads because i dont want to regret settling for gt40's
what all will i need for install
other than fel-pro gaskets and the bolts
Old June 2nd, 2009, 07:59 PM   #17
1992 Lx
11.39@119.24
thats it, bolts, gaskets (valve cover, timing cover, head, intake,) oil, coolant
Old June 2nd, 2009, 08:45 PM   #18
stfudvs's Avatar
302 5.0
should i get new spark plugs
Old June 2nd, 2009, 08:53 PM   #19
1992 Lx
11.39@119.24
duh!
Old June 2nd, 2009, 09:50 PM   #20
1998 Cobra
13.24@105.66
Autolite 25's!
weeee foooord!
Threads Similar to: gt40 heads
GT40 heads Red5.0sleeper General Tech 2 April 1st, 2009 10:05 PM
GT40 Heads fastford3388 5.0 Mustangs 6 September 29th, 2008 10:44 PM
gt40 heads? workinprogress 99-04 8 January 20th, 2008 05:07 AM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 09:34 PM
