Is true u cant run more than 75shot with stock fuel rails?
I want to run atleast a 100 shot with my kit(wet) but was told i cant cuz i still have have my stock fuel rails and i will starve my left(driver side) injectors.
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
i've never heard of that.....i had a friend with a 89 coupe he was spraying 175 wet shot on it...
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
Non-sense... stock rails will support enough fuel to crack the stock block lol 500 whp ish
weeee foooord!
Now that sounds more like it. I'm tapping the fuel from the schrader valve. Is that ok?
89mustanglx5.0
Dont beleive that. You CAN run 125 shot nitrous, I did on my stock engine. anything much higher and you need engine work first.
looking for a mustang again.! |
'89 LX 'Vert
10's or bust... Literally.
you will be fine.
just make sure you have everything set up. 1 step colder plugs, highest octane fuel (93/91), upgrade your fuel pump, (255 so you dont have to do it again), dont spray under 2500-3000rpm. ETC if you have a 93 5.0 you might only want to go up to a 125shot. also a dyno would be good. my jetting for a 150shot was off the chart's rich, flooding my intake with fuel. so i backed the jet's down. good luck!
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
#7 | |
lol where do people come up with this crap.. does this guy how told you this run synthetic blinker fluid or no
1995 Mustang GT
nope bet he used royal purple muffler bearing grease though...
#10 | |
1994 Ford Mustang GT
ran it in my flowmasters for years, keeps them nice and greased just like any muffler should be
www.moddedmustangs.com |
Atomized
ha ha muffler grease ftw
spray and pray |
Do you guys ever rotate your mufflers or am I the only one that does that??? How about your spark plug wires? Ya'll ever rotate them?
#14 | |
1995 Mustang GT
i bought a sawz-all muffler delete kit for mine....so never have to worry about getting them rotated again. as far as the plug wires heavens no, not on the street anyway, but at the track i put them all on in reverse firing order...and let 'er rip, it helps me pick a good 75-1000 HP, but if i did that on the street i'd have to get rid of the car much like the guy in your sig..it'd simply be TOO FAST!!
The Razor's Edge
my ship has 4 16 cyl engines....with more power....
Threads Similar to: Is true u cant run more than 75shot with stock fuel rails?
| fuel rails | TKOTLARZ | 94-95 | 3 | May 18th, 2008 11:39 PM |
| new fuel rails | zerofx150 | 99-04 | 3 | February 8th, 2008 08:36 PM |
| Fuel Rails | Euroeater95 | 94-95 | 9 | August 31st, 2007 03:10 PM |
| STOCK FUEL RAILS | Racinjason81 | 5.0 Mustangs | 21 | February 16th, 2007 02:21 AM |
| Help! Fuel Rails | Skullman | General Tech | 0 | September 24th, 2006 08:09 PM |
