#61 | |
1993 5.ohhhh
12.97 @140mph
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#62 | ||
The idle may have something to do with your tune, you don't know for sure because you haven't solved the problem yet. I think we've discussed this before and it could be the throttle body but I don't remember for sure. You've got that wrong. Performance at the track is everything. You can dyno your little heart out and still never have the car tuned as good as you will tuning at a race track.
#63 |
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#64 | |
#65 | |
1993 5.ohhhh
12.97 @140mph
Now I'm GUESSING, not dyno racing so don't take this the wrong way. I did dyno on a mustang dyno, and this dyno in particular reads rather conservative. My tq was 418 wcf, i Know my cracked plugged didn't allow me to get an hp number, but wouldn't you say maybe around 440 or so? That to me is a little much for the stock block. That seems a little much for stock block to me. My idle thing I don't get. It just dives betweens 500-1000 when cold, and once it's been drive it hits 0 on the tach and then bounces from there to 500. Just keeps me uneasy after ripping on it, Id get scared to death if it were to shut off on me.
#66 |
Very good stuff! If at all possible I try to tune everything myself via an e prom/emulator setup. Even though I am still an amatuer, I am capeable of tuning as well at 50% of the tuners out there.. and if I blow something out, it's my fault and I didn't spend hours on the dyno $$$$
But for sure, with those afr's, your car will run safely.. I say have him work on the idle issue, then take it to the track and the times will tell all! Interesting note: Most boosted cars are tuned for 11.5:1 WOT AFR (Safe rich tune)... But I tuned a 7MGTE supra for a friend, the best track times were at 12.9 air fuel with less timing. Cut the car off right at the end of the 1/4 and coasted into the pits, pulled a plug.. looked perfect. . Who knows..
weeee foooord!
#67 |
1993 5.ohhhh
12.97 @140mph
12.9
lol. Either way. What can you do on a chip to control idle, or mess with it. I was under the impression that with iac tps and the idle screw was all there was. When I first paid to get it tuned, he messed with those, but it didn't fix it. This retune was free, were cool with eachother now, so I just toss him a couple bucks. However I don't like bugging him. He's a distributor of parts who happens to own a dyno to test his products, so he doesn't tune cars for a living. Most of his money is made over phone calls, conferences, and meetings.
#68 | |
#69 | |
1990 LX hatch
As far as the block goes. assuming there are "fresher" bearings, and everything is in good shape, it varies. Some blocks crack at high hp, and rpm, but are still making in the 400 lb ft ratings, some crack at 3000rpms with 550 lbft. I would say at 450/450@6000rpms, if your engine is fresh, youll be fine.
#70 |
12.9. Were hard core.
Forged pistons are race gas ftw
weeee foooord!
Threads Similar to: hit the dyno again.
| NastyStang Hit VMP's Dyno Today !! | NastyFX4 | 2005 - 2010 | 29 | May 17th, 2009 12:35 AM |
| Dyno Tune at Dyno Tuned Performance | CW5billwade | 99-04 | 18 | March 20th, 2009 01:48 PM |
| Jan 19th Ft Myers - VMP Mobile Dyno - show, dyno runs and tuning by appointment | Justin00Stang | Southeast | 0 | January 4th, 2008 07:26 PM |
| Mustang Dyno vs Dyno Jet | BLOWN89 | 5.0 Mustangs | 18 | December 1st, 2007 10:34 PM |
| Mustang Dyno Global Dyno Day! | BadMoFo | Southeast | 1 | September 20th, 2006 04:09 PM |
