1993 5.ohhhh
12.97 @140mph
hit the dyno again.
Didn't get an accurate hp reading again. The base it did 388hp and like 360 tq. Then the next run it did 320hp and 438 tq. So It ate up my plugs
My guess is the hp is just a little over what the tq was. The best part was it was on a mustang dyno! So I'm happy. Idk the boost... It was to loud in the garge on the dyno to stand next to the car. Should be 14psi. It sucks I'm using gt40ps.... it flattens out the power band a little past 5200. Can't rip on it yet since it will break up but when I get new plugs on her she should ride out quite nicely.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1992 Lx
11.39@119.24
whyd it funk the plugs up?
how did the torque jump like that
The Razor's Edge
increase in boost?
1993 5.ohhhh
12.97 @140mph
I put a 14psi pulley on the car like said in the original post. I think the plugs were to rich... I haven't pulled em yet. I'm praying fixing the plugs wont eff the tune up, but it will pick up about 100 hp or so, so we will see.Car runs smooth as butter. Like I said before the plugs started breaking up untuned it did 388. So I imagine it's mid 4's.
The Razor's Edge
thats hot shit
so did you swap the pulley between those two runs?
The Razor's Edge
no he didnt
thats why i dont understand how the hp went down so much but the torque went up so much
The Razor's Edge
im not sure either....
1987 ford mustang gt
well see when shes done
I didnt know plugs broke up
How longs has it been since you put new ones in it and what were they gapped at.. Unless your car was pig ass rich i see no reason as to why the plugs went bad on you..
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
your dyno visits are always weird haha
#13 | |
I'm curious as to what rpm these numbers are at and I would like to see a graph of the pass with 438 ft/lbs of torque and 320hp to see what the lines are doing.
1993 5.ohhhh
12.97 @140mph
It made the 430ish at 2000 rpms. So low that it was still accurate. But then the hp across the board went to shit. That the was max hp and tq it it made across the run. Because it just fell off immediatly.
I'd like to see what the graph looks like. How do you know you have a spark plug issue.
what are you gapping at?
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1993 5.ohhhh
12.97 @140mph
I know it was a plug issue because it was misfiring at wot. They were gapped at .34. Idk if they were fouled out or the gap got messed up. I'm going to swap the plugs today so we will see.
so do you have a good tune on your car or will you have to go back again
#19 | |
How do you know it was a misfire and not a valve spring issue? Even if it was a misfire, there are more possibilities than just spark plugs.
i think you should be gapping a little closer than .034
Threads Similar to: hit the dyno again.
| NastyStang Hit VMP's Dyno Today !! | NastyFX4 | 2005 - 2010 | 29 | May 17th, 2009 12:35 AM |
| Dyno Tune at Dyno Tuned Performance | CW5billwade | 99-04 | 18 | March 20th, 2009 01:48 PM |
| Jan 19th Ft Myers - VMP Mobile Dyno - show, dyno runs and tuning by appointment | Justin00Stang | Southeast | 0 | January 4th, 2008 07:26 PM |
| Mustang Dyno vs Dyno Jet | BLOWN89 | 5.0 Mustangs | 18 | December 1st, 2007 10:34 PM |
| Mustang Dyno Global Dyno Day! | BadMoFo | Southeast | 1 | September 20th, 2006 04:09 PM |
