1992 mustang lx vert
Vortech boost ?
I'm new here, and have a question. Just installed a vortech v-1 sc trim on my 92 5.0 vert automatic. Doesn't start to make boost until the 3200+ range, trans shifts at 5400. And the most that I've on the gauge is @ 4 psi, should I upgrade to a larger crank pulley to bring the boost in lower, I'm going to install 3:55's(has 2:73). Currently running 19lb injectors, 70mm M/A, 190 lph pump, Have yet to install a typhoon intake w/ 70mm tb/spacer. Suggestions?
A centrifigul supercharger operates like that. The boost will not be instant like a positive displacement blower. Changing the pulleys will increase boost but won't make much of a difference for when it comes on. You are going to need bigger injectors if you turn the boost up at all.
yeah there are several upgrades you could probly benefit from with a blower...255 pump and probly 30 lb or bigger injectors bigger maf and throttle body....that intake isnt the best either....i realize you probly dont have money to throw around just letting you know....im not familiar with what charger is rated at what boost but what is that one advertised at
1994 Ford Mustang GT
vortech tells you how much you each pulley change will give you in hp gains, as for running a smaller pulley you will notice a quicker boost build up at lower rpms because the supercharger is already spinning faster, and higher boost numbers, if i had it my way i would have gone with a twin screw kenne bell, no build up period, just straight up and constant power/boost
www.moddedmustangs.com |
The Razor's Edge
i dunno about a kenny bell twin on a push rod fox....
you have stock exhaust? one you free up the exhuast and intake side you should notice a big difference |
1981 4 EYED FREAK
9.48@147
X2, that sounds right for a vortech... make sure you dont have any belt slip or boost leaks...
![]() www.rodeheavershotrod.com 9.48@147 on pump gas through the mufflers, still has pw,tilt,t-tops,all lights, wipers!!! , check out the vidhttp://www.youtube.com/watch?v=SloE3Zdetac |
The Razor's Edge
lol the most common thing you will hear after beating a srt4 in a race....."i have a boost leak"
#8 | |
yeah all you ricers have a list of excuses readily available |
1993 5.ohhhh
12.97 @140mph
If your going to want more boost. Get a bigger maf, a good maf, a bigger throttle body, bigger injectors.
Lightning maf is about 80 bucks used 42lbers can be had for under 200. And a used pulley is cheap. What pulley is on your blower right now. I have a 3.33 pulley I'm trying to det rid of for 50 bucks.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
The Razor's Edge
im no damn ricer!
haha i was just messin with ya man.....i think those cars are pretty cool....i just had to do it tho
The Razor's Edge
lol i hear ya
ill make fun of the yota |
#13 | |
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
The Razor's Edge
i still beat you!
1995 Mustang GT
i didn't hear the beep and you got the jump on me...lol, but hey i'll have the new tranny and clutch in any day now...so whenever you're ready we can hit up the track and see what happens.
The Razor's Edge
can i go in reverse?
im done with the neon....im selling it for sure when i get back |
Priest of the Car Gods
You might look at the flipside of the equation, and work on getting your tranny to hold more rpm before it shifts. Maybe I'm out of the loop on 5.0s, but 5400 seems a little low as a full-throttle shift-point to me.
The Razor's Edge
the stock tachs are almost always off....even up to 1k at redline....
1993 5.ohhhh
12.97 @140mph
Try making making decent power and having to shift at 5600-5800 cause my junk ass p heads.
When my car was almotor it was off by less then 1k. But with the vortech when I hit 4500 sometimes it would hit the rev limiter depending on the gear I was in.
#20 | |
1995 Mustang GT
just depends alot of 5.0's stock one's anyway are usually out of breath by 5400 rpms, just depends on the head and cam set up
Threads Similar to: Vortech boost ?
| how much boost?? | dudelinger | 4V / SVT | 11 | March 1st, 2009 08:21 PM |
| Vortech & Cams OR Vortech & After/Intercooler | StuTheMusicEngineer | 99-04 | 21 | January 4th, 2009 10:51 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
| Boost???? | MikeyS281 | 99-04 | 1 | September 8th, 2006 04:41 PM |
| vortech pulley size? boost? belt ? | faststang | General Tech | 20 | August 26th, 2006 09:17 PM |
