1988 lx
13.13@101.78
GT40p's
Just picked up a set from my local junkyard for 100 bucks for the set! What should i have done to them before i install?
![]() 302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's |
At minimum they will need to be resurfaced, new valve seals, new valve springs and a valve job.
and to be honest i did actually copy and paste that from one of darrells posts.....i mean 1slo5.0 |
The Razor's Edge
+1
and im pretty sure your header will fit im assuming your running the stock cam to....? |
1988 lx
13.13@101.78
running an E303
The Razor's Edge
should be a decent gain....
1988 lx
13.13@101.78
i hope so! i'm so close to 12's its irritating the hell out of me, so i figured a deal like that for the heads wasn't bad at all. Hoping to be around 12.50's
The Razor's Edge
your not going to gain half a sec bro
1988 lx
13.13@101.78
well i actually plan on launching it. my 13.13 run was coming off the line at an idle, so next time i plan on taking it to about 3k. I'm running on a 4cylinder tranny so breaking it on the line is my fear.
The Razor's Edge
spin to win! get us posted bro...
1988 lx
13.13@101.78
Would it be worth it to have them ported? i'm going to send em out anyways
The Razor's Edge
you might as well.....raise compression a lil bit
1988 lx
13.13@101.78
thanks for the input. Anyone suggest a certain spring style and or brand i should go with?
No. If you are going to pay for porting on top of all of the other stuff these heads will need, you might as well buy some good aluminum heads.
1990 LX Coupe
Gasket match the ports yourself and get the Trickflow spring kit and you'll be good.....
1988 lx
13.13@101.78
how do i go about doing this?
Do not do anything said above....
PeteAndersonRacing.com |
The Razor's Edge
lol yeah save up get some aftermarket....darrell came out with a great point
1988 lx
13.13@101.78
so you guys just suggest having them resurfaced, new valve seals, new valve springs and a valve job.
At minimum. I'd probably toss in some new retainers and valve locks right away.
u might consider a kit somthing like this
Trick Flow Specialties TFS-2500100 - Trick Flow® Valve Spring Upgrade Kits |
Threads Similar to: GT40p's
| stock 302 header worked with gt40p's? why | 5.0 street stanger | 5.0 Mustangs | 14 | June 8th, 2010 11:05 PM |
| Not sure if I want to risk GT40p's. | TN.Frank | 5.0 Mustangs | 66 | April 23rd, 2009 03:01 PM |
| Pedestal conversion kit for gt40p's? | 93hatch | 5.0 Mustangs | 1 | June 20th, 2008 05:09 PM |
