F303 cam with GT40 heads
Old June 3rd, 2009, 03:57 PM   #1
ballajb is on a distinguished road
is there anyone else running this combo of gt40 heads with f303 cam? if so what length pushrods did you go with?
Old June 3rd, 2009, 05:31 PM   #2
rodeheavers's Avatar
1981 4 EYED FREAK
9.48@147
rodeheavers is on a distinguished road
you should be able to use stock length pushrods becuase an f-cam has the same base circle size and your stock cam..
www.rodeheavershotrod.com
9.48@147 on pump gas through the
mufflers, still has pw,tilt,t-tops,all
lights, wipers!!!, check out the vid
http://www.youtube.com/watch?v=SloE3Zdetac
Old June 3rd, 2009, 05:31 PM   #3
The Razor's Edge
White Thunder's Avatar
what are your mods? keep the stocker cam and forget the alphabet cam
founder of the FTN Club
Old June 3rd, 2009, 06:22 PM   #4
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Stock pushrods and rockers worked on my car. I also have gt40p's and a fcam.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old June 3rd, 2009, 09:11 PM   #5
Always measure.....Every motor is different.
PeteAndersonRacing.com
Old June 3rd, 2009, 09:57 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1 +1 and +1 one more time.
Can't stress this enough whether it be valve to piston clearance or pushrod length. You just don't know if the heads have been milled or if anything else has been done that will affect the clearance.
Old June 3rd, 2009, 10:01 PM   #7
1981 4 EYED FREAK
9.48@147
so if he has a stock cam in it and if the heads/block were milled or valve seats reground, then it would prob have different length pushrods or rocker shims to start with.. but yes it is best to check..+1
Old June 3rd, 2009, 10:33 PM   #8
1993 5.ohhhh
12.97 @140mph
Originally Posted by rodeheavers View Post
so if he has a stock cam in it and if the heads/block were milled or valve seats reground, then it would prob have different length push rods or rocker shims to start with.. but yes it is best to check..+1
lol... Kinda got a point there. But mustanks right. The combo you want has been done one trillion times... but oddly enough some people have different results.
Old June 4th, 2009, 11:44 AM   #9
PJC Racing is on a distinguished road
Measure for correct length.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
Old June 4th, 2009, 01:58 PM   #10
1998 Cobra
13.24@105.66
Pull And Pray, Pull And Pray Brother
weeee foooord!
Threads Similar to: F303 cam with GT40 heads
f303 cam Crob09 5.0 Mustangs 7 December 30th, 2008 09:24 PM
What heads to go with an F303 cam? sixxxshoooter 5.0 Mustangs 58 November 12th, 2008 11:36 PM
f303 cam at .50 worlz08 5.0 Mustangs 3 May 28th, 2008 09:37 AM
Looking at the F303 cam 94stangGT50 5.0 Mustangs 5 April 5th, 2008 03:27 PM
