need help- other forum didnt reply.
Old June 4th, 2009, 06:44 AM   #1
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
so my buddy has a 1990 ediie bauer edition bronco with a 302 in it. he changed the oil pump and now it will turn over but wont start. the fuel pump is getting power to it but i dont here it prime when he turns the key on. weird part is the truck ran fine 2 weeks ago before the pump went. any help?
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD.
Plans: full black interior, black paint and supercharger???
Old June 4th, 2009, 09:28 AM   #2
kilby91's Avatar
1991 Mustang GT
kilby91 is on a distinguished road
So he changed the oil pump and now the fuel pump doesn't work???
Old June 4th, 2009, 09:43 AM   #3
1988 LX Procharged 347
Procharged 347 is on a distinguished road
[SIGPIC][/SIGPIC]
[FONT="Arial Black"][SIZE="4"][COLOR="Red"]Procharged 347 stroker [/COLOR][/SIZE][/FONT]
Old June 4th, 2009, 09:50 AM   #4
The Razor's Edge
White Thunder's Avatar
how long did it run with the bad pump. To
founder of the FTN Club
Old June 4th, 2009, 10:07 AM   #5
haywood11's Avatar
1988 mustang lx
interior torn out!
a shop said the pump was going bad so it was replaced. the guys at the shop were trying to dick him around and tell him he needed parts that he actually didnt. so he towed it home and tried to start it and it turns over but no start. btw, power is getting to the pump. should i spray starting fluid in the throttlebody to see if it starts?
Old June 4th, 2009, 11:34 AM   #6
PJC Racing is on a distinguished road
You need fuel, spark and compression to run....One is missing. How did he replaced the oil pump, was it in chassis?
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
Old June 4th, 2009, 11:43 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Does the vehicle have fuel pressure? If so, how much? Does the vehicle have spark? I wouldn't worry about compression because nothing was messed with that would affect compression. Was the distributor removed when changing the oil pump?
Are you sure they were dicking him around? I bet the truck would be running right now if the shop fixed it. How do you know he didn't need the parts they claimed he needed? Apparently your buddy isn't a professional in the field so I don't know how him or you are qualified to make that accusation.
Old June 4th, 2009, 10:15 PM   #8
haywood11's Avatar
1988 mustang lx
interior torn out!
well if you call leaving the old oil pump in the oil pan and re-attaching it and never telling him, i would say thats dicking him around. the truck has spark, and the distributor was never touched. and no he is not a pro at it hence why im working on it. just figured i would get a little input....
Old June 5th, 2009, 12:53 AM   #9
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
i would say give it a very slight shot of starter fluid/spray, the more you use the more the damn thing wants it, if it fires up pump the gas to it and it should stay running, sometimes you gotta give it alittle jump and then things start running like they should
www.moddedmustangs.com
Old June 5th, 2009, 01:16 AM   #10
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
i wud check fuel pressure to see if your gettin any
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old June 5th, 2009, 07:22 AM   #11
haywood11's Avatar
1988 mustang lx
interior torn out!
so i can just take the guage off my stang and put it on there to test the fuel pressure?
Old June 5th, 2009, 12:32 PM   #12
1986 mustang gt
1fst5.0 is on a distinguished road
hit the tank near the fuel pump a couple times while u have sumone cranking it. it may start but that means the pumps on its way out. hit it with sum carb cleaner, if it starts, its ur pump.
Old June 5th, 2009, 07:02 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If that's what they did then why didn't you say that in the first place? Leaving everything apart is totally different from what you originally said "trying to dick him around and tell him he needed parts that he actually didnt".
Old June 8th, 2009, 09:12 AM   #14
haywood11's Avatar
1988 mustang lx
interior torn out!
my apologies i type like a quadrapalegic so its hard for me to write everything down. im trying to get to it today ill kepp yall posted.
Threads Similar to: need help- other forum didnt reply.
Reply from Ford 06RedfireGT The Clubhouse 17 February 5th, 2008 02:10 PM
Need a quick reply stang94 94-95 0 September 10th, 2007 10:09 AM
Need a reply fast. MustanG_guy17 V6 Mustangs 4 June 5th, 2007 05:12 PM
reply error 99mustang232 Feedback Forum 1 March 24th, 2006 10:20 AM
