13.64@101mph
87-93 5.0 5lug conversion
hey guys...been a while..but im gunna be doing a 5lug conversion on my friends mustang and well i've done one cheap before with aerostar/ranger axles and that crap...but he wants it to be a little more quality...so any suggestions or changes to this...thanks
front: new cobra 13" rotors used cobra 2 piston calipers hub? will any hub work with those rotors? v6, gt, cobra/ abs, non abs hubs? will sn95 spindles work with those rotors? what brake lines do i need? master cylinder? upgrade brake booster? rear: new cobra rotors used cobra calipers used 5lug foxbody aftermarket axles, ie moser, strange etc... missing anything?
SN95/Swap ebrake cables
brake lines
weeee foooord!
13.64@101mph
will the e-brake cable from an sn95 fit a foxbody? and i know i need brake lines! who sells the conversion lines? or what adapter have is there out there to mate the sn95 lines to the fox ones...
Let me call up my friend Nathan and i'll see what he did to be 100% sure.
weeee foooord!
13.64@101mph
okay thanks...are all 94-04 cobra front brakes 13"? cuz i found a set for $39.99 new each for 94-04 cobra brakes (stock replacement for now)
#6 | |
aka Nature boy
blk 89/red 91 XJ Limited
I like turtles
The Razor's Edge
sup punk ass
aka Nature boy
I like turtles
03 GT, 92 coupe 2.3T
to use the cobra calipers will require some material removal on the spindle. all 94-95 gt,cobra, and v6 spindles are the same. Some places charge more for gt and cobra parts. use stock 94-95 hubs. they won't increase the track width. the 99-04 spindles and hubs will increase the track width by 8mm per side.
2003 DSG GT 5-speed full bolt on's 03 cobra irs swap 18x9/18x10.5 TF mach 5 wheels
13.64@101mph
okay so i can do sn95 spindles and hubs...i already ordered the 13' cobra front rotors and 11.65" cobra rears for him...can i use GT calipers from the 99-04's, the PBR's i think they call them for now until he can come up with some money for the cobra ones..also sn95 brake lines and e-brake cables should work with this..plus already ordered moser 31slpine axles for 79-93 5lug...(doing 4:10s same time) thanks
2009 ROTY
for what its worth the cobra caliper is a PBR caliper. and your gonna need the pbr cobra calipers to clear that rotor. the rear calipers are the same with the gt's and cobras. the difference is the thickenss and diameter of the rotor. along with the mounting bracket for the caliper.
13.64@101mph
so i need the cobra calipers for the front but i can use the GT ones for the rear with the 11.65''s? also is there a bracket for rear disc brakes i NEED for these? also am i going to need to upgrade the master cylinder and brake booster?
i found a set of 99 cobra front calipers, pads, brackets, spindles, hub's and brake lines...for the front..do i need anything else? (already have new rotors)
13.64@101mph
for the rears what is the anti moan bracket? what else do i need besides this stuff
front: rotors calipers and bracket pads brake lines hub spindle dust shield rear: axles & axle bearings rotors calipers and bracket pads brake lines dust shield i need a comprehensive list so i dont forget anything...thanks
Threads Similar to: 87-93 5.0 5lug conversion
| v8 conversion | fasteststangever1 | 5.0 Mustangs | 18 | March 6th, 2009 03:33 PM |
| 5lug converson | worlz08 | 5.0 Mustangs | 1 | July 13th, 2008 04:17 PM |
| 5lug conversion | Speedstang302 | 5.0 Mustangs | 3 | May 9th, 2008 07:34 PM |
| 4lug-5lug conversion | DCstangGT | 99-04 | 2 | May 20th, 2007 11:10 AM |
| 5lug conversion rims? | fakesaleen | 5.0 Mustangs | 2 | February 14th, 2006 04:43 PM |
