Solid Roller vs Hyd. Roller
Old June 5th, 2009, 02:19 PM   #1
68 dlxcoupe's Avatar
2004 Mach 1
13.30 @ 104.47
68 dlxcoupe is on a distinguished road
Send a message via AIM to 68 dlxcoupe
What are the differences between hyd. a solid performance wise?? I am considering going with this setup on my 91, but I'm not sure if it would be overkill for a forged 306 with AFR 185's or TFS Highports? Thoughts and opinions? Also what would need to be done to accommodate the lifters on a roller block or would I have to get a non hyd. roller block??
http://www.moonshine-media.net/68dlx2.jpg
EAGLE SCOUTS OR GTFO
MyStangOpens (12:01:05 AM): honey nut for me
Old June 5th, 2009, 02:22 PM   #2
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
They make solid roller lifters that will fit your roller block as OEM lifters do. Solid lift cam/lifter combos make quite a bit more hp and require just a little more maintenance than a hyd set up.
FluffyTheRhino:
One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards.
1988 Notch 347 C4 w/brake 3.90 gear
11.19 @ 122mph 60' 1.67 N/A
Full Interiored pump gas car
Old June 5th, 2009, 03:03 PM   #3
PJC Racing is on a distinguished road
Solid rollers tend to make more power due to being able to increase valve spring rates that allow for more aggressive cams and vise versa. Solid lifters are just that, solid which requires you to set valve lash to buffer the valve train. Hydrualic's use oil pressure to buffer the valve train. You do not need to anything to run solid rollers in a roller block, but it is recommended that you use link bar lifters for reliability, and they are not cheap.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress)
86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
Old June 5th, 2009, 03:07 PM   #4
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
exactly how much maintenance are we tlking about here.....do you adjust the lifter itself or what.....and how often would you have to do this
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old June 5th, 2009, 03:39 PM   #5
No, you periodicly have to pull the valve covers and check valve lash. It is not hard at all, EFI with large plenums do cause a bit more labor though because you have to remove the upper plenum to remove tha valve covers.
Old June 5th, 2009, 04:06 PM   #6
2004 Mach 1
13.30 @ 104.47
I see, I am switching from EFi to a carb setup anyways so I'm not owrried about that, I just love the sound of a solid roller over hydraulic. Thanks for the info guys!!
Old June 5th, 2009, 04:11 PM   #7
1988 Notchback
11.19 @ 122mph N/A
There is some pretty aggressive sounding hyd roller cams out there. Don't just make your decision upon that.
FluffyTheRhino:
Old June 5th, 2009, 04:53 PM   #8
2004 Mach 1
13.30 @ 104.47
I'm not switch just for that reason. I am trying to make a nasty all motor 306 and I am trying to expand my options on how to make power
Old June 5th, 2009, 07:34 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Solid roller all the way. No such thing as over kill. Have the cam ground for your combination. Camshaft Innovations has a pretty good deal on Canfield/custom cam and Trick Flow/custom cam packages.
Nothing needs to be done to the block.
Old June 6th, 2009, 01:37 AM   #10
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
setting the valve lash
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old June 6th, 2009, 11:04 AM   #11
Proud American
MustangMatt96GT's Avatar
Which is very easy to do. Solid is the only way To go. Even if it were my daily driver.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old June 6th, 2009, 04:22 PM   #12
Fijistudios's Avatar
Cobra soon?
Fijistudios will become famous soon enough
x2 pricier... but you have to pay to play
---2003 Ford Focus- VF Engineering Vortech kit, Tein suspension, etc. Fun DD
---2.1 Kenne Bell 1987 Mustang Lx-465rwhp/520rwtq SOLD
you both launched like you were chloroformed by a potential rapist
Originally Posted by FluffyTheRhino View Post
Cliffnotes: I just took a dump.
Old June 6th, 2009, 06:28 PM   #13
You should not be concerned with sound, you should be concerned with performance. There are a lot of very nasty cars out there that idle like they are stock, they are just set up correctly.
If you are serious about stepping up, I would contacy Camshaft Innovations for a custom tight lash solid roller and head package. The heads would already be set up with the correct parts for the cam. However if you are not ready to buy, do not try to contact him until you are ready. I believe his head and cam packages start at $1800, but don't quote me on that.
Old June 7th, 2009, 07:29 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old June 8th, 2009, 12:39 AM   #15
2004 Mach 1
13.30 @ 104.47
I am not ready to buy yet, I am just researching and saving at the moment. The sound isnt the only reason its just a little extra pleasure on my end, but I'm just trying to get the feel for pushrods again since i've been all over mod motors for the past 4 years.
Threads Similar to: Solid Roller vs Hyd. Roller
Solid roller cam??? flamed 98 gt 5.0 Mustangs 26 February 21st, 2009 03:03 AM
solid roller lifter vs. hyd flat lifter ... pushrod length? ryans88gt 5.0 Mustangs 5 December 10th, 2008 12:19 AM
Solid Roller vs. Hydra Roller Goblin 5.0 Mustangs 58 November 30th, 2007 02:22 PM
Hydrolic roller to Solid/Mechanical roller hitorx 5.0 Mustangs 2 May 14th, 2007 05:12 PM
