Mass air meter question
I got a meter on ebay and i took the sensor out and the 4 metal prongs were bent and the little resistor had broken off. I bent the 4 rods back straight again, but the sensor was broken off. Can I solder it back in place, or does the sensor have to be replaced? Are those prongs supposed to just stick out or do they attach to something? If I cant fix it can I just get a new sensor? Where can I get one and what do they cost? How do I post pictures on here? I havent figured that out yet? I took some photos of it but i dunno how to attach them.
No, the meter is junk. That is the part that senses the in coming air.
1988 LX Procharged 347
host them on photobucket.com and then copy and paste the [IMG] tags
[SIGPIC][/SIGPIC] [FONT="Arial Black"][SIZE="4"][COLOR="Red"]Procharged 347 stroker [/COLOR][/SIZE][/FONT] |
1990 LX hatch
Dont try and soder it. it measures how much voltage it takes to maintain a constant temperature. Oil, dirt, and im guessing especially sodder will skew the readings.
where can i buy a new sensor to drop in it?
1986 mustang gt
u can try to get one at ur local autoparts shop, it will do the job. or a junkyard
This is why you should stay away from fleebay.
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress) 86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
i payed next to nothing for it. So is there any web sites that sells just the sensor? I dont know how those c&l meters but they dont come with the sensor. Do you use the stock one or does somebody sell just the sensor? I dont even know where to begin if i were to look at the junk yard. What kinda car would I want to pull the sensor out of If I went that way? its an 80mm if that helps. can I just take a sensor out of any car that has #24 injectors? What about explorers? what size injectors do they have? Or maybe a ford truck? I have no Idea. Ill call advanced auto, but i dont think they will have it. Can somebody point me in the right direction? Can I put my stock sensor in it for now until I get the #24 injectors, and get this figured out?
1989 GT
KB 2.1L Flowzilla
Get rid of it, and go to a junkyard and find one listed in here: Corral Forums - View Single Post - Used MAF testing, and MAF interchange on different Ford vehicles
#11 | |
#12 | |
#13 | |
I don't know why anyone would want to use a stock mass air meter from any of those vehicles anyway.
#14 | ||
1989 GT
KB 2.1L Flowzilla
I've found it to be a somewhat popular upgrade for people not changing to bigger injectors. Maybe not making a huge improvement on hp, but better throttle response have been reported. I did notice a small increase on boost when i switched to F2VF MAF. Used MAF testing, and MAF interchange on different Ford vehicles - Corral Forums Cobra MAF - Mustang Forums at StangNet When do you need bigger fuel pump and injectors - Ford Mustang Forums Junkyard Horsepower SUMMARY! - Corral Forums |
Threads Similar to: Mass air meter question
| mass air meter question. | 5.0 street stanger | 5.0 Mustangs | 7 | May 22nd, 2009 09:46 PM |
| mass air meter question | gotn20 | 5.0 Mustangs | 3 | May 11th, 2009 11:35 PM |
| Mass air meter | cobrarob | 4V / SVT | 1 | April 9th, 2008 10:26 PM |
| Mass Air Meter | Euroeater95 | 94-95 | 7 | November 16th, 2007 04:00 PM |
| Mass Air Meter Question (Cobra 70mm) Help | cobraetti | 5.0 Mustangs | 0 | October 30th, 2006 05:52 PM |
